RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Echo CS-300 (https://www.rcuniverse.com/forum/engine-conversions-92/6480452-echo-cs-300-a.html)
Ralphbf 10-12-2007 04:02 AM
Echo CS-300
I recently picked up an Echo CS-300, real cheap.
With a new ring I'll have almost $20.00 in this thing and it looks real promising.
Reed valve near the bottom of the crankcase and large ports.
It's rated from 10,000 to 12,000rpm
I'm thinking gas-glow to start with, but wondering about the prop hub, any ideas where a guy could pick one up?
Does any one have experence with this engine?
Thanks in advance
.......Ralph
wingspan99 10-14-2007 04:30 PM
RE: Echo CS-300
Ralph check Carrprecision.com, wackerengines.com or ch-ignitions.com for prop hubs for weedie engines. Try matching up the shaft that protrudes out the flywheel, there's some basic sizes and a hub for a homelite or ryobi might just screw on. Echo makes good engines, the boat drivers use the 23cc size a lot and run them fast too, just watch your rpm's with a cast flywheel, they can fly apart. I'd say any engine worth converting for RC should have electronic ignition, you can adjust your spark advance way beyond the few degrees used on weedie flywheels, and get a lot easier starting, and if you go for broke and get electronic advance, you can hand prop it in a lazy fashion with no kickback. It's been my experience that you need a very fast flip on a hand start or a beefy electric starter to get a magneto engine going. Not to mention the weight of the flywheel and coil. You can usually drop about 12oz with electronic ignition. Ch-ignitions.com can supply it all. -Tom
buck1856 10-15-2007 11:03 PM
RE: Echo CS-300
I assume your going to loose the flywheel so your looking for a hub that will fit over the shaft plus screw on the threads.Or use just the center of the flywheel and screw on a short hub against the cut down flywheel hub.what thread size is it.should be 8x1.2mm.Right hand.
