RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   This Cement Saw shall fly !!! (https://www.rcuniverse.com/forum/engine-conversions-92/6573872-cement-saw-shall-fly.html)
Ralphbf 04-15-2008 12:06 AM
RE: This Cement Saw shall fly !!!
1 Attachment(s)
Well guys I took the easy way out.
I added a 3rd exhaust pipe and it made the difference.
The 1st 2 pipes went about 3/4 the length of the muffler and were 45ed and faced the back wall.
The new pipe is as flush to the bottom of the muffler as I could get it.
It may not be developing top power but watch me rock back when I rev it up.
The thing falling off the other side of the fence is a metal sign.
It was blown off a large head screw that barely fit through the hole.
This should make a 15 pound plane jump into the air.
My biggest concern now is ground clearance for the prop.
It is easily turning a 22x10w prop, probally a 24x10w would drop the rpm a little.
But I'm going to need a 3-blade prop for ground clearance.
Anyone have experence with a 70 something cc engine and a multi blade prop?
Compair this video to the 1st one.
2nd Video: http://rcuvideos.com/item/GYZZ4BDXYD2G4VVP
1st Video: http://www.rcuvideos.com/item/BMV2KV388GZSF0NZ
meridianclocks 04-15-2008 05:46 AM
I think you should try the motor in the goped in the background!:D
Rich
tkg 04-15-2008 01:02 PM
If you want to slow it down with out going to a 24" prop, change to a Zoar 22x10. TheZoar has a much higher load factor than an APC
Ralphbf 04-15-2008 01:28 PM
I need a 3 blade for the ground clearance.
tkg 04-15-2008 08:16 PM
3 bladed big props are big $$$$, care for bigger wheels???
tim220225 04-15-2008 09:40 PM
Ralph that thing screams. Makes me happy to know the concrete saws do work and work well. What does it weigh as is? One of these days I will finish my DVIII I am building and then finish the 70cc Husqvarna I started and then get on the two saws I have left.
Ralphbf 04-16-2008 12:32 AM
It weighs in at 4lbs, 4oz.
Your probally right about the bigger wheels.
I could always hand lanch it and land dead stick :-)
