RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   $25 CDI (https://www.rcuniverse.com/forum/engine-conversions-92/6870043-%2425-cdi.html)
captinjohn 11-07-2008 09:03 AM
RE: $25 CDI
Carpilot...Very good imformation! It is good to find what sensors will work with different CD units. This makes it all more afordible for us all. Please keep up the good work! Capt,n;)
Bladejunkie 11-07-2008 10:10 AM
RE: $25 CDI
Thanks Carpilot,I've got the XYZ sensor too,but I like the easy clamp setup on the CH unit.I guess I'll just use XYZ stuff.I tried the unit with the CH hub and got a nice blue spark.I just have to drill and tap my Homie for the sensor and I'm good to go.Thanks again for the info Carpilot.
Jim
av8tor1977 11-07-2008 10:25 AM
RE: $25 CDI
If someone would look at the XYZ sensor carefully with a magnifying glass, you might be able to find some numbers and possibly a manufacturer. Then you could probably buy them at one of the electronic supply houses like Digikey for about fifty cents....
AV8TOR
captinjohn 11-07-2008 05:06 PM
RE: $25 CDI
Bladejunky,Please post a photo of your set-up when you get it going. Thanks Capt,n
terrymf 11-07-2008 05:41 PM
RE: $25 CDI
I am wondering if you would even have to use a specific sensor or if any one would work???
This site has some for 2.00 for 4..thats .50 cents each.
[link=http://www.goldmine-elec-products.com/prodinfo.asp?number=G1994&variation=]Electronic Goldmine[/link]
captinjohn 11-07-2008 09:13 PM
RE: $25 CDI
Ask BigBoat if it would work....he is a wiz on CD ignitions. Capt,n
terrymf 11-07-2008 09:31 PM
RE: $25 CDI
Also..here is a potential source for the magnet needed on the prop hub to operate the sensor
[link=http://www.eamagnetics.com/info_alnico_magnets_prodphotos.asp]magnets[/link]
kenhiraihnl 11-07-2008 11:29 PM
RE: $25 CDI
i've been getting magnets from this place for years...ken
http://www.kjmagnetics.com/proddetail.asp?prod=D11-N52
Patxipt 11-08-2008 04:38 AM
RE: $25 CDI
Petrol is British English for US English Gasoline.
Then you have Heavy and Light Diesel fuel.
markaboo929 11-08-2008 03:11 PM
RE: $25 CDI
http://www.prcmodel.com/modeng/name/...e%26catid%3D21
Add $8 for shipping ($44.50) to US this is in Canadian dollars equal to US Dollars is $37.44
http://finance.yahoo.com/currency/co...submit=Convert
AND it works flawless down to 4.4 volts I got 1 hour running time on a 4.8 v 600 Ma Nicad pack!:D
radio shack 1/8 th magnet $1.99 for 2
it shows us dollars but unless they updated it I got it for the $37 dollars
captinjohn 11-08-2008 08:07 PM
RE: $25 CDI
ORIGINAL: markaboo929
How long did it take to get this $37 ignition. Sounds good! Capt,n
markaboo929 11-09-2008 10:37 AM
RE: $25 CDI
I ordered it on a Sunday on line and recieved it on that Saturday basically 1 week from Canada to North Carolina,They look like they are located near Michigan,Upper state New York area.Not to bad and it works real good.I have it set up on an Echo 1.3 and I am breaking it in on a Evolution 15x6 prop.It has been hitting a little above 8000 rpm ,now thats running on 32:1 oil ratio with lawboy oil.The throttle responce is quick almost like there was no prop on there.Instant.Almost finshed with a gallon of fuel through it.I will go with a 50;1 synthetic ratio after that.
markaboo929 11-09-2008 10:40 AM
RE: $25 CDI
I just tried to click on the prc link and it just goes to the empty cart-just go to crrc pro replacement parts,the ignition is for the 26 as well as the sensor.
av8tor1977 11-09-2008 11:44 AM
RE: $25 CDI
Does anyone know if the CRCC ignition is auto advance??
The unit for the 26cc engine is listed at $35.00, and the one for the 50cc engine is listed at $38.00. I wonder what the difference is between the two??
AV8TOR
EDIT: I checked the 26cc engine description and it says it has auto advance.... Still don't know about the price difference.
Bigboat 11-10-2008 08:12 PM
RE: $25 CDI
Most common hallsensors are uni-polaire.
A uni-polaire needs only a south form the (neodymium) magnet to switch on / off
A bi-polaire sensor needs a south to switch on and a north to switch off.
http://parts.digikey.co.uk/1/1/87891...37-wl-7-b.html
captinjohn 11-10-2008 09:15 PM
RE: $25 CDI
ORIGINAL: Bigboat
Big Boat...to put it simple, if our pic-up sensors have only one magnet ....are they neodymium? Like-wise if they are bi-polar...you need 2 magnets in hub? I got a feeling you could make the answers a lot more imformitive to us. Capt,n
av8tor1977 11-10-2008 09:21 PM
RE: $25 CDI
Hmmm.... made perfect sense to me...
AV8TOR
nitro joe 11-10-2008 09:40 PM
RE: $25 CDI
ORIGINAL: Bigboat
Thank you,Bigboat.
I've wondered about that,nicely put.
captinjohn 11-10-2008 10:01 PM
RE: $25 CDI
ORIGINAL: captinjohn
ORIGINAL: Bigboat
Thanks for the edit...more data for us to read= more imformation!
Bigboat 11-11-2008 05:49 AM
RE: $25 CDI
ORIGINAL: Bigboat
Most magnets they use for CDI are neodymium becourse they are very strong and small becourse they are strong.
If your using a biopolaire, you don't need twoo magnets, but you have to position the magnet the hallsensor can read both sites.......norht and south.
If your using a *horsshoe* magnet, you don't have a problem.
One leg will be south and the other will be norht.
A long (straight) magnet gives your trouble, becourse the norht and south feeld are on top of the magnets in a straight line.
captinjohn 11-14-2008 11:20 PM
RE: $25 CDI
Wow! That sure was fast on the delivery. Which unit was that again? Thanks Very much, Capt,n
markaboo929 11-16-2008 09:05 PM
RE: $25 CDI
It is for the replacement on the crrc pro 26i in the replacement parts section.I am going to get a nother one for my homey 30cc i have just aquired.And the radio shack magnet works just fine just pass it by on either side and one will make it spark going in the correct roation-counter clock wise-I was trying both sides and it actually will spark with the other side of the magnet in the opisite dirrection!!! hmm.........imagine just having a twin engine plane with counter rotating engines!!! And by the way sometimes my echo 21.2 will start and run in reverse pretty decent too...just wont have full throttle.:D
markaboo929 11-16-2008 09:12 PM
RE: $25 CDI
there on sale as i type this $31 for the ignition $5 for the sensor!!
dsdemer 11-28-2008 02:17 AM
RE: $25 CDI
Please post a link to the $31 ignition. I got lost with all of the websites. Thanks-Dana
terrymf 11-28-2008 03:49 AM
RE: $25 CDI
This one is 33.59.
Not sure if it is the one refered to earlyer in this thread or not...
http://www.hobbycity.com/hobbycity/s...or_FTL_Engines
