TT 91fs idle
Ran my TT91 for the first time this weekend. Started and ran no problems. Used Powermaster 30% heli fuel and a 14/6 APC prop. After three 12 oz tanks I tried to get it to idle but the lowest I could get it was about 3100 rpm without the glow driver on it. I was just wondering how low can I expect to get it to idle. :confused:
Thanks, Neil |
TT 91fs idle
You might want to post this in the engine discusion forum.
TT 91fs idle
First run 2 to 3 more tanks of fuel. Use a Fox Miricle or OS F plug and at least 10% nitro. Ignore the lumpy idle, it should idle at 2,800 even less with more run time. Use the pinch test to be sure that the mixture is set right. It should speed up a bit a second or so after pinching the fuel line.
| All times are GMT -8. The time now is 10:24 AM. |
