Walbro carb numbers to specs sheet?
Does anyone know where I can find a spec sheet that will give me the venturi size and the carb number?
Thanks Jim |
RE: Walbro carb numbers to specs sheet?
Walbro .com under products lists all carbs with specs
Walbro is where I go when I need info just like the last poster says.
There is a list on this thread: http://www.rcuniverse.com/forum/m_23...tm.htm#2381120
The Walbro website is a good source as well, and has parts blowups, venturi size, etc. AV8TOR |
Hello Jezmo
How about a reverse lookup venturi mm -> model ? Traverse matching through walbro's and zama's carb list is a waste of valueable time. Must be some spreadsheets floating around. /Munin |
Thanks guys. That was the info I was looking for. However, I agree with Munin. I wish there was a list that had all venturi mm to model numbers listed. Would make looking up the specific carb you wanted easier. The other way works ok but requires a little more effort. Can't complain though as I dont have the time to do it myself. Anyhow thanks for the website.
Jim |
If you follow that link I posted, it has a long list of carb numbers, listed with the venturi sizes and other pertinent info.
AV8TOR |
Thanks Av8tor,
I printed off the thread you linked to and it has great information. It is limited though. What would be nice is to have a list like that one for all the sizes. With all the carbs that Walbro has made though that would be a monumental task. One I wont complain about because I know I dont have the time for it. Jim |
Here is what I use
[link=http://www.prestwich.ndirect.co.uk/walbrocarbs.htm]Walbro Carbs[/link] |
The truth is, I wonder what all the subtle differences are between all the many different model numbers that Walbro offers??? We all struggle to have a nicely tuned engine, but what exactly do the manufacturers do to assure that a specific carb is "perfectly" mated to their engine in question?
Food for thought... AV8TOR |
Hello av8
Carbs are to my experience abit of a hassle. To show you what I mean take a look at this informative link. http://bonzisports.com/carbs.html I think this is what tickles Jim. /Munin |
fowlmood77
Nice list, glad you posted it. I had seen it sometime ago and then misplaced its location. |
| All times are GMT -8. The time now is 11:09 PM. |
