Husqvarna 25
1 Attachment(s)
Ok Gang, here's the latest motor project, you can blame this one on Sears, I needed a new bandsaw blade and noticed that they had the Huskey weedeaters on sale :D Four lbs even straight out of the weedeater
Husqvarna 25
1 Attachment(s)
A couple of hours work and it's down to 1lb 11oz. Looks promising!
Husqvarna 25
1 Attachment(s)
Getting close the next day, 2lbs 11oz without the muffler and ignition.
Husqvarna 25
1 Attachment(s)
I mounted the ignition pickup and magnet on the rear of this one.
Husqvarna 25
Good job; Looking at that first pic I would have never thought it would have turned out that nice. How is the power??
Adam |
Husqvarna 25
1 Attachment(s)
About four flips with the choke on to get a pop, then about 4 more flips to get it running. After that, one flip starts. Getting 7650rpm with an APC 16x10 right now but this engine has less than a tank of gas through it so far and I'm expecting a good bit of improvement. Dual rings, excellant compression, beautiful throttle response. Only snag, it's got one of those oval shaped intake ports like on the Poulan 46 so building the carb adapter is a little work (understatement)
Husqvarna 25
hey flip looks like you could use a lighter muffler maybe a pitts style for some good sound ,nice motor mount also
Husqvarna 25
What is the displacement and what weight did you end up with for an all up finished unit? Engine.ignition,muffler,prop hub ?lbs.
conversions
flipflop: Thanks for the nice photos. Your work on the engines you have done looks very good...as usual! Smooth landings Captinjohn
RE: conversions
1 Attachment(s)
Well I finally got around to doing some more prop testing with the baby Huskey, this time with a B&B muffler on it
APC 16x8 8250rpm APC 16x10 7760rpm APC 17x6 8550rpm Bambula 16x8 8490rpm MA 16x8 (three blade) 7680rpm MA 18x8 6850rpm I've got to get this motor on a plane and get it broken-in. |
RE: conversions
Looks Great! What are you using for ignition? What's the weight with/without ignition?
Cheers Bill |
RE: Husqvarna 25
Just took it off the test stand and weighed it, 3lbs 4oz. with the muffler, C-H ignition (with Bosch cap) and Dubro mounts. One of the plastic motor mounts might save a little more weight.
| All times are GMT -8. The time now is 03:38 PM. |
