RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   After market Ignition system (https://www.rcuniverse.com/forum/engine-conversions-92/7689233-after-market-ignition-system.html)
frenchie79 07-03-2008 08:39 AM
Can anyone recommend an after market EI system for conversions. Is their a inexpensive system that can work for many engines, basically for testing. Is CH the best choice in value.
arobatx 07-03-2008 09:39 AM
RE: After market Ignition system
Get one from Ralph Cunningham...last I knew he was able to pass on the best deal, for a REALLY good ignition:
1783 Whitehall
P.O. Box 636
Williams, AZ 86046
928.635.2455
captinjohn 07-03-2008 11:16 PM
Yup...get that ignition from Ralph.....best service you will find...and very good prices!;)
frenchie79 07-07-2008 03:16 PM
Not getting an answer on the phone number-could you please check that-Thank-you
buck1856 07-07-2008 10:04 PM
Ralph has been out in California for a week.He just got back last week.Keep trying.Probably better in the morning.
JIMARRINGTON 07-08-2008 05:00 PM
I have been using the XYZ replacement ignition from southeastrcengines.com. Have one on a Ryobi 31cc that works great so far. Only a few flights. But price is good. southeastrcengines.com
Jim
Ralphbf 07-08-2008 07:54 PM
How did you set up the hub?
Hole saw the flywheel?
buck1856 07-08-2008 08:15 PM
1 Attachment(s)
Heres a pic of my 31cc ryobi i just did.I also put the cylinder in my lathe to round it out some for a more finished look.Holesawed flywheel.3-1/4 lbs as in the pic with ign and mount.Rcexcel ign.Just drilled and tapped 6x32 in the front case for sensor.
captinjohn 07-08-2008 09:43 PM
If a person has a aircraft with a standoff box on firewall...you could just use a flate plate of aluminum to mount the Ryobi. Also a light muffler built from a aluminum beer bottle. Lots of options!!! Capt,n:D
JIMARRINGTON 07-09-2008 10:09 AM
Yes, I used a hole saw to cut out the flywheel for the magnet hub. To mount the sensor I epoxied the sensor to a screw hose clamp then mounted the clamp to the crank case.
Jim
