RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Adding a ring? (https://www.rcuniverse.com/forum/engine-conversions-92/771063-adding-ring.html)
Volfy 05-13-2003 10:42 PM
Adding a ring?
With the impressive results folks are having with the newer twin-ring Ryobi 31cc vs the older single-ring versions, plus the fact that most of the "pro-grade" industrial engines (e.g. Kioritz, Echo, Zenoah, etc.) all have dual ring pistons, wouldn't it be a fairly simple hop-up to machine an extra groove on a single-ring piston to accept a second ring? Afterall, larger automotive engines typically have several rings - some for compression and some for oil control.
It shouldn't be all that difficult if you have access to a lathe, should it? Has anybody tried this?
ANeat 05-13-2003 10:50 PM
Adding a ring?
Some pistons have a little extra meat where the ring or rings are and as you move down the skirt it gets thin pretty fast. On the Ryobi I dont know, If there is enough material there it should be a pretty straight forward modification. A fixture or something to hold the piston might need to be made up to keep from crushing or scaring the piston in the chuck of a lathe.
Adam
Volture 05-13-2003 10:50 PM
Adding a ring?
I thought about doing this on an old single-ring small Ryobi (26 cc -- not the 31) and decided there just wasn't enough space above the wrist pin hole to squeeze one in. On other engines this might be doable. I too would be interested to hear if anyone has done it...
DougT 05-13-2003 10:58 PM
Adding a ring?
Why couldn't you just order a new 2-ring piston and stuff it in the old engine? Unless the pin diameter, bore, stroke, shape, and weight are different, it should work.
Doug
flipflop 05-13-2003 11:14 PM
Adding a ring?
It's going to take more than an extra ring to get the power of the old motors up to that of the new one. The new cylinder has a larger more "D" shaped exhaust port that is unbridged. The best that I can remember, the transfers ports are a little different too, but don't quote me on that, it's been a little while since I've had them apart to compare. I really can't see why the guys want to buy the old refurbished motors from Harbor Freight when you can get a new twin ring from Wal-Mart for around $69. There is a big difference in power between the old one and the new one.
Volfy 05-14-2003 01:43 AM
Adding a ring?
Actually, I really had Poulan chainsaws in mind. With Ryobi twin ring refurbs going for $49 a pop, it really doesn't make much sense working on the old ones. The bigger Poulans (46cc, 50cc, 54cc, etc.) are still all single-ring and might just benefit from a second ring.
ZAGNUT 05-14-2003 08:29 PM
Adding a ring?
Volfy, maybe you can find a dual ring piston from a different engine/make that fits or can be made to fit? you might also find something with a taller crown to allow a compression increase. talk to some long-time saw shop guys, if it's a possibility they would be the ones to know.
dave
