RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   big bore carb????? (https://www.rcuniverse.com/forum/engine-conversions-92/7772303-big-bore-carb.html)
tractor1964 07-25-2008 06:36 PM
big bore carb?????
i am converting a 31cc ryobi for my supersportster and i found a walbro carb that is 15mm on one side and where the choke is its 18mm. how can i find out what model it is?? on the choke its stamped 62-40 and on the top 21-245-5-4 on the side were the high and low needels are HDA 60 k1. will it make a big difference in rpms to go to a bigger carb? thanks john
nitro joe 07-25-2008 07:14 PM
RE: big bore carb?????
http://wem.walbro.com/walbro/product...m=HDA%2D60%2D1
captinjohn 07-25-2008 09:52 PM
I could be wrong....but a HDA Carb may be a little to big for a 31cc ryobi????? Capt,n
pe reivers 07-26-2008 08:32 AM
11mm is about right. The membranes are the restricting factor. Trumpeting the entrance duct to the largest size the membrane petal will seal brings a substantial increase in power.
captinjohn 07-27-2008 12:46 PM
Pe R. Is that like a pirimid block of reed valves. Thanks Capt,n
nitro joe 07-27-2008 06:49 PM
1 Attachment(s)
I wonder if this is what is meant by:
“Trumpeting the entrance duct to the largest size the membrane petal will seal brings a substantial increase in power.”
bat.guy 09-04-2008 11:41 PM
tractor dude-you need a WT324,391 or 347 or I've heard but haven't seen 167. Except I've heard that some 167's have trumpeting membranes. Very noisy,I bet.
