RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   prop. size (https://www.rcuniverse.com/forum/engine-conversions-92/7808579-prop-size.html)
rwb93 08-04-2008 06:20 PM
prop. size
1 Attachment(s)
hi,
working on a conv. of a lawm boy mower engine that is 2 stroke that's 127cc .what is a good size prop. to start with?
frenchie79 08-05-2008 09:38 AM
RE: prop. size
How much does that bad boy weigh? Should be an interesting mount to the firewall. Please post if you get it running. I don't know if the copper tube to the carb will keep the carb cool, but give it a shot. The pipes are interesting, did you solder them with regular solder???
Don't know on the prop, but at 127cc-get one off a ultra lite!
rwb93 08-05-2008 05:39 PM
RE: prop. size
Hi,
It is 9lb with the flywheel, 6lb without. Looking to going with electronic ignition.
No, all the solding was done with silver solder it has a higher melting point then reg. solder.
Looking to start with a 26'' prop. what do think?
captinjohn 08-05-2008 08:46 PM
RE: prop. size
I think be real carefull with that meat chopper!!! Capt,n[X(]
andrew66 08-05-2008 09:46 PM
RE: prop. size
what kind of plane are u thinking of putting it in?
rwb93 08-06-2008 04:16 AM
RE: prop. size
don't know yet. till i get it going .get some ideals
microsprint9 08-06-2008 05:11 PM
RE: prop. size
ORIGINAL: rwb93
hi,
Check the mower blade diameter and pitch that was on it that should get you close. LOL.
rcairboater 08-07-2008 06:26 PM
RE: prop. size
Looks like a 26" to 28" prop with a 10to12 degree pitch. Here is a link, these guys can help ya.
http://www.desertaircraft.com/page.php?Page=Menz
-Gary
foamcut 08-09-2008 08:53 PM
RE: prop. size
RWB,
Let us know your progress.
What size carb did you use?
