RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Offset carb adapter needed (https://www.rcuniverse.com/forum/engine-conversions-92/7914080-offset-carb-adapter-needed.html)
jg4660 09-02-2008 09:25 PM
1 Attachment(s)
Does anyone know where to get a carb adapter similar to the Zenoah g20/g26 type that would rotate the carb about 90 degress counter clockwise so the throttle linkage could be connected without any type of bell crank? I converted one of the MAC engines and it runs great but not sure how i'll connect the throttle linkage if i can't rotate the carb...i really want to avoid a complicated bell crank if possible. Heres a couple pics so you can visualize this and 1 of what this engine started out as.
JG
buck1856 09-02-2008 11:01 PM
RE: Offset carb adapter needed
Horizon hobby.Its called an easy link carb adaptor for the G23-26.It has all the bolts,and carb arm.$11.95 if i remember right.Plus shipping.
jg4660 09-03-2008 05:32 AM
I looked at that easy link adapter and it seemed similar to the one that i have on it as far as the bolt pattern. I'll check it again..Thanks
arobatx 09-03-2008 09:14 AM
If that doesn't line up, give Ralph a call...he makes em:
Ralph Cunningham
928 635 2455
[email protected]
jadec241 10-20-2008 01:34 PM
Try wackerengines.com He makes one for the 25cc & 33 cc. Works great
captinjohn 10-20-2008 07:31 PM
1 Attachment(s)
Even better yet in some tight installs. Capt,n
buck1856 10-20-2008 10:35 PM
Alright captn,you got me.Where did ya get em?
Bladejunkie 10-20-2008 11:07 PM
Captin,thats just what I need for my GX35.I could keep everything under the cowl of my 1/4 scale Fokker D-VII with one of those.Where can I get one?
arobatx 10-21-2008 09:14 AM
www.toni-clark.com :D they are sized for popular Zenoahs, so have your intake port measured, and special attention if you need a pulse port....and bolt spacing before you start shopping....unless the capt has another source.
www.DavesMotors.com also has some pretty trick stuff for scooter engines, many of which will share something close for intake port measurements, that you can modify on your own.
captinjohn 10-21-2008 10:21 AM
ORIGINAL: buck1856
Buck...thats just photos of the intake adapters. I right click on a photo I want to save and place it in Picasa. Then I can show things like that. A photo is worth a thousand words. Also I can study the part and try and make one with my mill and lathe. I got photos of about every trick engine thing I have seen on a computer!!! Capt,n
buck1856 10-21-2008 10:35 PM
D@#M,i thought you might have had them on your workbench for sale.I was hoping you found a whole new meaning to narrow cowl.Good pic though.I have a very thick chunk of G-10 i might try making up somthing like that some day.
captinjohn 10-21-2008 10:41 PM
Wish I did have some of those adapters on my bench....at least I would have something with some value!!!!!!!!!!:D:D Capt,n
