Help with 31cc Ryobi conversion
As stated in a previous post. I have a Ryobi 31cc converted to EI with a CH ignitions prop adapter and their magnetic sensor. I'm using an S/S ignition system which is almost new. I have a Walbro WT-324 carb. on it. I'm running a Zinger Pro 16x8 prop but no muffler on the engine yet. I have the timing around 30 deg. BTDC. I replaced the throttle shaft so I could add a throttle arm on it. BTW, Ralph Cunningham sent me the replacement throttle. Great guy!! Anyway, the engine starts great. Choke it till it fires, choke off, one or two flips and it's running. Now here is the problem(s). The engine will idle but I have the idle stop screw all the way out and it still idles at about 2300 RPM. I can add throttle quickly and it will take throttle great. I have the top end adjusted pretty close and the bottom end pretty good I think. When you let it come to idle quickly, it will quit. One or two flips and it's running again and idling as before. I have the LS needle out about 2 1/4 turns. Any leaner and it won't transition quickly to full throttle. I have the spark plug gap at .020" which is brand new.
I did have the butterfly out when I changed the throttle shaft out but I think it is the right way. I have compared it to other carbs and it moves the right direction and is in with correct side out. I do have a little light showing around the sides of the butterfly but I have tried to adjust it but can't seem to get it touch all the way around. The butterfly does touch at the top and bottom. I have looked at the carb end where the butterfly is and there is one tiny hole exposed like the other carbs I looked at. As you open the butterfly, the is another tiny hole that then becomes exposed. I believe these are for the low speed circuit because carb cleaner came out of these holes when I sprayed carb cleaner in the hole where the LS needle is. Any Ryobi guru's have any ideas? Thanks |
RE: Help with 31cc Ryobi conversion
too much air getting past the throttle butterfly, are there any holes in the plate? if so, solder them shut one at a time until you get the idle you want, and if there's a little hump of material removed down by those holes in the carb bore, try soldering some of that down as a last resort.
is this carb the stock or larger than stock? |
The carb plate doesn't have any holes in it so there is nothing to solder shut. This is a bigger carb than the original. It seems that the WT-324 is the carb recommended for this conversion. The original carb is 7.54 mm and the WT-324 is 11.1 mm.
Take some wd40 and spray around the bottom of carb and around the black plastic base that bolts up to the crankcase and check for leaks.If theres one the engine will change rpm.Do this at idle.
yep, that would explain why the needle is needing to be out that far
I haven't had a chance to try the WD40. I have looked over the plastic back plate where the carb mounts and the reed valve area and didn't see anything where air could leak. I used red RTV to seal the gasket to the crankcase and the back plate. One thing I noticed is that the reed valve isn't sealing when it is just sitting in place. The engine starts and runs good so I can't see how the reed valve not seating fully is the trouble. Is the reed supposed to seat when the engine isn't running? Will the reed seat when the engine is running?
Thanks |
A few months back some buddies at the field were having idle problems with a G-62. The end result turned out to be a crack in the plastic carb spacer. They replaced the carb and plastic spacer from another G-62 and fixed it. You couldnt see the crack until you had the spacer off the engine.
Edwin |
The last time I had this happen, it was the carb butterfly being worn and allowing too much air to pass when closed. Hold the carb up to a light, and when the butterfly is closed, you should not see any light showing through the carb. This can also happen if the butterfly isn't aligned perfectly when installed.
Good luck, AV8TOR |
The carb is new and has never been mounted until I installed it. I did remove the the butterfly to install a different throttle shaft. I do see some light but it shows around where the shaft is. I think I have it aligned properly. I have tried numerous times to get it to touch all the way around but can't seem to. I looked at other carbs that are new in a box and they have some light showing in the same general areas. I'll try to run it this week some more and try the WD40 trick to see if anything shows up. Is there a way to align the butterfly properly? Mine is touching about 95% of the opening but like I said, I have other carbs that are showing about the same amount of light.
Thanks |
I tried the WT-324 on my Homelite 25cc and never had any luck with it. I bought the carb for a G26 at my LHS (WT-644?) and haven't had a problem since. Just want to point out it may be the carb.
Did you mean to say no muffler at all[X(] or just not a modified muffler yet? The right back pressure (at the right time) is a big part 2 stroke tuning. With no back pressure the intake charge can blow right out the exhaust port at certain RPM. Trouble is with bigger carb the stock muffler can have too much back pressure esp. at higher revs. A good set up witih 11mm carb is replace the 1/3"ID exhaust outlet pipe with 7/16"ID. Bigger than that is not necessarily better. Means a little cutting and brazing but at any rate I wouldn't try to tune the intake without the muff you intend to run.
I don't have a muffler at all on it. I want to make sure it runs fine before I spend money on a muffler from wackerengines.com. I need it to idle reliably and at a lower idle. The darn thing starts great and runs WOT great. The HS needle adjusted fine. It's the darn idle that baffles me. I haven't had a chance to run it any more. I took the carb off and checked the butterfly again. I tried once again to adjust the butterfly to get more of a seal. I hope to run it more in the next few days.
Thanks |
Madman,
You won't get it right without a muffler... i'm afraid you need to invest in one to find out how it runs an then determine what it will take to make it purr. Cheers, |
Not having a muffler shouldn't cause it to idle too fast. If I understand the problem, he can't get the engine to idle slower even with the carb butterly all the way shut. Sounds like it is getting air from somewhere. Pull it all back apart and go over it with a "fine tooth comb". Somewhere air is getting in, and supporting the fast idle even with the carb butterfly shut. Cylinder base gasket, carb adapter/reed block, spark plug not seating/sealing; somewhere air is getting in that shouldn't.
AV8TOR |
What's really confusing is how he handles all the noise[:-].
In order to get the engine to run properly, there needs to be backpressure. Having no muffler likely won't cause his problems but the engine will never tune properly so why avoid the inevitable... put a freaking muffler on it and eliminate that issue is all I'm saying.
Cheers, |
EAR PLUGS!!!!!!!!!!!!!!
Actually most engine builders test their engines for Max. rpm with no muffler.
Ralph at rcignitions.com is one of those engine builders. |
ORIGINAL: Ralphbf Actually most engine builders test their engines for Max. rpm with no muffler. Cheers, |
And if one happens to want to use a tuned pipe, the first step in the process is to check WOT rpm, WITHOUT A MUFFLER.
AV8TOR |
ORIGINAL: av8tor1977 And if one happens to want to use a tuned pipe, the first step in the process is to check WOT rpm, WITHOUT A MUFFLER. AV8TOR Cheers, |
No, your wide open throttle rpms with no muffler gives you a baseline. Then you install the tuned pipe long, and start shortening it a little (about a quarter inch) at a time. When the rpms stop increasing, make the setup about 1/4" longer and fly it. The rpms you end up with over and above what it did without a muffler is an indication of the increased power the pipe is providing. (and lets you know it's working!)
AV8TOR |
AV8TOR, I did have a conversion to gas/glow running super...for a short time...read about it in another posting. Capt,n P.S. How is that Echo doing I sold you?
Yeah, I answered that in the other thread Captain. But I just had another thought....
If that engine was new or rebuilt, it might have "eaten" the glow plug. I have found that when running a new or rebuilt engine on Gas/Glow, that it will usually ruin a glow plug while the engine starts breaking in during the first few tanks of fuel. The tiny metallic particles shed during the initial break in contaminate the plug. I usually use an old, crappy glow plug for break in for that reason. After a few tanks of fuel, you can put a good glow plug in, and then they last a really long time. AV8TOR |
Made some headway on this conversion. I took the carb off and took it partially apart to clean it up. Readjusted the throttle plate. I only see light where the shaft goes thru the body. I also put gasket sealer on the carb base gasket. I seems to run better now and idle a little lower. I think the higher idle is carb related. I sprayed WD40 around the base of the carb and back plate gasket. I'm not sure what was supposed to happen but nothing changed at idle. I'm able to lean the LS needle more now. I even had to richen the HS needle some. The high speed is a little rich. Transition to WOT is pretty smooth. If I let it idle for abut 3 minutes and then open the throttle quickly, it spits a little gas from the carb and stumbles ever so slightly thens clears up. Once it's cleared out, it throttles up quickly nice. The LS might be a little rich yet. I want to get a muffler and 18X6 prop on it before I fine tune it.
I did notice that when I sprayed WD40 around the carb, the WD40 would run down to the open exhaust which would atomize it. It would then get sucked into the carb and the idle would increase. |
| All times are GMT -8. The time now is 01:42 AM. |
