RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   supertiger 3250 (https://www.rcuniverse.com/forum/engine-conversions-92/7957233-supertiger-3250-a.html)
rc pilot 09-15-2008 04:28 PM
supertiger 3250
How would someone go about turning the 3250 onto a gas burner??? exactly??
tkg 09-15-2008 07:26 PM
RE: supertiger 3250
Add ignition.
Make a better conversion, add ignition and Walbro carb
Best, add walbro, ignition and retap head for a 10mm plug.
Never mind needle bearings on the rod.
rc pilot 09-15-2008 07:50 PM
RE: supertiger 3250
and how would you go about that???
buck1856 09-15-2008 07:54 PM
RE: supertiger 3250
Buy the items from ch-ignitions.
Or from rcignitions.
stryder 09-18-2008 05:38 PM
RE: supertiger 3250
Is there any more info on this conversion method?? was considering this myself. A RCU search yeilded nothing. Thanks, George
tkg 09-18-2008 07:25 PM
RE: supertiger 3250
Search Gas engines section for ST 3250, a bunch there.
oldtimer2 09-19-2008 08:55 AM
RE: supertiger 3250
EDITED
tkg 09-19-2008 09:37 AM
RE: supertiger 3250
Think real hard about WHY you want to do this conversion. Its easy to do but cost around $200 for all new parts to do it right.
You end up with a light and lightly built engine with good power. It requires carefull ducting to keep from over heating ( gas runs hotter that glow)
Ralphbf 09-19-2008 11:20 AM
RE: supertiger 3250
I have one of these and have been thinking about running it on Gas-Glow.
I would have to maintain the same oil content, but believe this would be a good conversion.
No ignition, no bearing changes. Just mix the fuel and try it.
At 1/3 glow fuel and 2/3 gas and a target of 10% oil content I'd have to add 12% more oil to a 10/18 glow fuel
to maintain the 10% over all oil content. .... If my math is right.
KenLambert 09-26-2008 09:18 PM
RE: supertiger 3250
I am doing 3 of the 3250's but will put a needle bearing in the rod and a hard pin in the crank , my .90's are turning an apc prop 15x4 w 10500 on average and my 2300 is flying a 1/4 scale edge ( WH ) like a rocket , never have tached it lately but have probably 4-5 gallons of 50:1 klotz synthetic from day one .
