Walbro carb adapters?
So I'm thinking about converting my Thunder Tiger 1.20 to gas. Rather then use the stock carb, I'd like to use a Walbro carb on it. Is there some where (or some one) I can buy an adapter from?
Thanks, Dave |
RE: Walbro carb adapters?
If you dont find anything,pm me.......could probably make you one.
Look here just scroll down a bit.I would contact them to see if it would fit.
http://www.nelsonhobby.com/prospark.html It is listed for an OS 1.08 |
ORIGINAL: markaboo929 HERE YA GO!!!!!! Been done before!!! http://tech.flygsw.org/ scroll to engine conversionsTT 1.20!!! Thanks Mark, that's actually the article that is motivating me to do the conversion. Unfortuantly, the gentleman doing the conversion custom made his adapter. I don't have any way to machine my own. |
Yeah I saw that,but,you might be able to contact him about one.maybe-dunno.Some good info on what to expect though....or you could contact the club?Or look at there forum to see if the person that did it is there?
What is the O.D. of your barrel on the bottom of your stock carb.If you could,in mms and inches.I have one made up but am not going to use it.It was for a ST90-91.Ill have to take another pic and post later.
| All times are GMT -8. The time now is 05:36 AM. |
