RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Ryobi engine mount (https://www.rcuniverse.com/forum/engine-conversions-92/8679655-ryobi-engine-mount.html)
cutarug 04-14-2009 04:40 AM
Ryobi engine mount
I have had great success with my Ryobi (XYZ) ignition ,swings a 20 x 10 and idles at 1000 RPM.
I am interested to find out how many engines are mounted solid to the firewall and how many are rubber mounted.
My motor has rubber cushions on the stand off's but I have been recently told this reduces the power of the engine when compared to a hard mounted engines.
Any comments on this?
jeffy 04-14-2009 08:41 AM
RE: Ryobi engine mount
thats a simple one....
real race cars have solid motor mounts........
Laird SS 04-14-2009 11:01 AM
real race cars probably don't have as much concern for vibration as aircraft do.
Twin Star 04-14-2009 12:02 PM
Very few model aircraft have rubber engine mounts, whether they are Ryobi powered or not. Rubber mounts will definitely reduce airframe vibration noise from the engine but as far as engine performance, there may be some truth. I've seen modelers use rubber mounts for their novelty, just to remove them later. That should tell you something.
If you decide to test rubber engine mounts, post your performance results.
buck1856 04-15-2009 12:53 AM
Real race cars have to put torque to the rear wheels.
If i tromp into my 350 with an Eldebrock intake and 4 BBL on my truck you can see how much the engine raises up on the rubber mount.
Unless you want to burn rubber with your landing gear it doesnt seem to matter.
I have used both on my conversion engines.Solid to firewall,and with some 1/4 inch and 3/8ths inch rubber washers behind standoffs and flat mount.Didnt have any performance diiferrence that i could tell.
I couldnt afford solid motor mounts when i was in high school so we used a short piece of chain bolted to the block,then to the frame and left the rubber one there as well.Only needed one on the drivers side for the torque.
So unless you want to burn rubber or get a hole shot and go vertical in 5 feet on takeoff,i personally would do what you want.
Ralphbf 04-15-2009 03:23 AM
I'm with buck on this one.
I have a US 35 mounted on a rubber motor mount and it just runs smoother, as in less vibration.
No noticeable power loss and a lot less vibration.
By the way Tony Clarke makes a mount with a cable in it to limit the rubber mount's movement.
So there probally is some power loss at full power, especially when a lot of throttle is applied all at once.
