Poulan Mounts??
Hi,
What's everyone using for an engine mount for the Poulans?? If you are buying them, where do you get them, and anyone have pics? Thanks, AV8TOR |
Poulan Mounts??
Hanger 9 large aluminum beam mounts
Poulan Mounts??
The H9 mounts are the best but H9 has been listing them as OUT OF STOCK.
DuBro makes some large isolation beam mounts that will work also if you cannot get the H9 ones. Jim |
Poulan Mounts??
Thanks guys!
AV8TOR |
Poulan Mounts??
I've seen pictures of various Poulan Engines - Some have mounting lugs on the side like normal RC engines, and some (like mine) don't. I made my own mount from an aluminum push plate (the kind on doors where you push to open) from the local home renovations store. I don't have pictures of it, but it looks very much like this one:
http://www.skylites.freeserve.co.uk/...al/plate-2.jpg I trimmed the back cover plate to match the engine profile, then placed the mounting plate over top and drilled the holes to match. I then replaced the bolts with ones which were 1/4 inch longer and went right through the mount and cover plate, into the engine casing. |
Poulan Mounts??
[QUOTE]Originally posted by w8ye
[B]The H9 mounts are the best but H9 has been listing them as OUT OF STOCK. Figures........ :mad: |
Poulan Mounts??
I prefer the GP 1.20-1.80 composite mounts. It's lighter and adjustable without changing the mounting hole positions. It's plenty strong enough to handle the 46cc.
BTW, I don't see how you could use a backplate mount for the Poulan chainees. |
Poulan
check out rcfaq.com, look under weedwacker conversions, lightened engine..Take a 3" round block of 6061 and mill and turn away anything that doesn't look like a mount...Nope, I don't convert any more Poulans, and don't make mounts....
Poulan Mounts??
Ahhhhh, shucks...
Poulan Mounts??
Originally posted by Volfy I don't see how you could use a backplate mount for the Poulan chainees. <Edit> If you don't want to make your own backplate mount, they can be purchased from numerous conversion sources, including CH-Ignitions $11.95: http://www.ch-ignitions.com/image9V0.JPG |
Thanks for all the input guys....
Sounds like the GP mount is what I would like to use.
Take care, AV8TOR |
| All times are GMT -8. The time now is 01:25 AM. |
