RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   WALBRO CARB INFO NEEDED (https://www.rcuniverse.com/forum/engine-conversions-92/8941767-walbro-carb-info-needed.html)
tinsink 07-17-2009 03:23 PM
Can someone give me any details as to the Walbro WT-503 carb? I would like to know
if there is a parts list or configuration for this carb. Rebuild kit info is also a help.
w8ye 07-17-2009 07:06 PM
RE: WALBRO CARB INFO NEEDED
WT-503-1 13.49 mm STIHL No longer in production
tinsink 07-18-2009 03:37 AM
Thank you for the info.
rangerfredbob 07-18-2009 04:17 AM
as for a rebuild kit D10WAT should be the gasket kit, K20WAT has the regulator needle and lever in it and a few other things, these work with walbro WA and WT carbs, if you search a little online you can get the smaller of the two kits for a little over $2 each plus shipping
