RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   EI Magnet Installation (https://www.rcuniverse.com/forum/engine-conversions-92/8964742-ei-magnet-installation.html)
J-3 07-26-2009 09:47 AM
When installing a magnet in a prop hub do you use epoxy to hold the magnet in? or maybe steak the edge of the hole?
I have not done this before and need a little guidance.
Thanks....
w8ye 07-26-2009 02:37 PM
RE: EI Magnet Installation
I usually stake them.
pe reivers 07-26-2009 04:22 PM
I use Loctite 648, which is as stong as epoxy, and heat resistant beyond the temperature where the magnet goes weak.
If need be, stake with a few punch marks. I know 3W does it like that. (The centre punch staking)
J-3 07-26-2009 07:16 PM
Thanks for all the inputs. I have epoxy on hand and I will add a stake or two...Brian
Scota4570 07-29-2009 06:58 PM
CH Ignitions told me to use JB weld. I did, it works. He also told me that Locktite is not 100%. He was not keen on staking them. I imagine that is because the magnet might break.
w8ye 07-29-2009 09:17 PM
You don't want to be banging a punch with a hammer around a magnet
You can do it with a press
Jezmo 07-29-2009 11:11 PM
I use epoxy and then stake them. My converted ST51 has turned over 17,000 with a pipe on it and nary a problem with the magnet. It regularly turns 15,000 with the current setup and has been running for about 2 yrs with the same magnet installation. Like the Energi*er Bun*y it just keeps going and going and going.
