RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   87cc toro 4 cycle (https://www.rcuniverse.com/forum/engine-conversions-92/9258953-87cc-toro-4-cycle.html)
foodstick 11-16-2009 09:00 PM
87cc toro 4 cycle
Anyone see one of these yet? On a small snowblower? The local hardware store guy knows I am a conversion guy. Soon as I walked in the door he was pointing it out.
Thought I would bring it up as I don't think I have seen it mentioned yet.
After a quick search online it might actually be a 98cc .85 liter ? Powerlite single stage?
I checked again today it is an 87cc toro 4 cycle, so I changed the title of the post to reflect that.
N99JH 11-19-2009 08:20 PM
RE: 87cc toro 4 cycle
Do you plan on converting one? I would love to see it.
foodstick 11-20-2009 02:31 AM
Well I am like you, hoping someone else takes the lead :D
My buddy is considering it for a 1/3 pup..but he says until someone determines the bearing setup. either firsthand or with a factory drawing he is sitting on the fence as well.
I am not really an expert in conversions as much as I follow the lead of more accomplished mechanics...
TxDiveBomber 12-09-2009 12:05 AM
1 Attachment(s)
Found these pic's of the engine not sure if it's any help to ya
Nosedragger 12-09-2009 09:28 AM
That has to weigh a ton.
w8ye 12-09-2009 11:14 AM
It appears to be designed along with the time honored B&S WET SUMP system
Nosedragger 12-09-2009 11:24 AM
Yup thinking that same thing, probably not a good candidate for conversion.
foodstick 12-09-2009 11:49 AM
well my buddy was looking at it for a 1/3 sopwith pup, so the weight might not be as big of a problem....He hasn't looked at one in person though...yet
w8ye 12-09-2009 11:57 AM
With a wet sump oil system, your maneuvering would be limited.
JohnF 12-09-2009 01:59 PM
If you make it a gas/glow conversion the oiling will not be as much of a problem. Others have had success with the B&S 40cc, 4-stroke with wet sump.
