RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Bernzomatic al3 rod (https://www.rcuniverse.com/forum/engine-conversions-92/9273178-bernzomatic-al3-rod.html)
Scota4570 11-22-2009 08:47 PM
Bernzomatic al3 rod
I used some if this stuff with a map gas torch and seem to have gooten good results. I made a couple of mufflers out of aluminum using plate, the base of a gas cylinder and a weedwacker handle. Everything was turned on a lathe so it was as clean as it gets. The rod flowed nicely and made a nice fillet. Anyone else using it? Does it hold up?
w8ye 11-23-2009 12:35 AM
RE: Bernzomatic al3 rod
They seem to be widely available
http://www.acehardwareoutlet.com/%28...aspx?SKU=24760
http://ec-images.acehardwareoutlet.c...ucts/24760.jpg
richg99 11-23-2009 08:36 AM
I used something similar that I bought at a boat show. I "welded" some flat aluminum plates onto a landing gear rig. It held up well for a number of my crash...whoops..landings. Rich
Nosedragger 11-23-2009 11:52 AM
I never had much luck with it, it would stick but any real force on it and it would crack.
coralcape 11-24-2009 10:06 AM
I have used these rods with medium success. The secret seems to be that you have to tin the surfaces first. I find if I do this the joint lasts much longer, It is also necessary to have a good mechanical join before brazing. Vibration is the enemy of this material. Good luck, red
