RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   ASP Radial to Gas (https://www.rcuniverse.com/forum/engine-conversions-92/9515421-asp-radial-gas.html)
kolmol 02-18-2010 03:13 PM
ASP Radial to Gas
Hi All!
Is it any chance to make ASP FS400 run on gas?
http://www.hobbycity.com/hobbyking/s...er_Glow_Engine
Nikolay.
bcchi 02-18-2010 03:23 PM
RE: ASP Radial to Gas
Are you are a qualified machinist a total gear-head and love self induced headaches? If you meet these qualifications then it is possible..
kolmol 02-18-2010 03:53 PM
I'm a scale warbird pilot :-) and what I really want it to get a cheap fuel scale engine.
Moki is to large for my models, and to expansive. THat' I think about idea to convert a multi cylinder glow engine to the gas.
Ralphbf 02-18-2010 05:41 PM
To do a simple conversion to gas is possible.
Running it on gas would still involve the same amount of oil to fuel ratio.
The bearings need the same amount of oil on glow fuel or gas.
The electronic ignition system would take some serious thought.
What you might consider is a gas glow setup.
It still runs with glow plugs but it is a 2/3 gas 1/3 glow fuel.
I have ran single and twin engines and some run real well and some not so well.
The ones that like it idle slower have a better mid range and higher top end.
The higher the compression the less nitro is needed.
High compression seems to work better than lower compression.
There is a whole bunch of info on RCU about it
Don't give up on the idea.
Opinions are like ears .... everyone has a couple of them.
av8tor1977 02-18-2010 09:06 PM
Man, that's a nice looking engine for a super price. Wish I had the bucks....
AV8TOR
