RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   WHAT TYPE OF CHAIN SAW IS IT??????????????????? (https://www.rcuniverse.com/forum/engine-conversions-92/9677378-what-type-chain-saw.html)
Falcons Cuz 04-21-2010 03:59 AM
HELLO GUYS
I HAD SEEN YOU GUYS CONVERTING WEED EATER AND CHAIN SAW GAS ENGINES FOR RC AIRCRAFT USE SO I DECIDED TO CONVERT ONE OF THE CHAIN SAW ENGINE BUT WHEN I REACHED AT A SCRAP YARD AND LOOK FOR SOME CHAIN SAW ENGINES I FOUND SOME MISTUBHI CHAIN SAWS BUT THEIR CARBS DONT HAVE SMALL RUBBER BALLS ON IT AS A WALBRO CARB HAVE
THEY ARE NOT A FLOTING TYPE CARB BUT THESE CARS HAVE THE SAME STRUCTURE AS WALBRO CARB BUT THEY DONT HAVE A BALL ON IT
SO PLEASE TELL ME THAT IS IT OK TO USE THESE ENGINES WITH SUCH A CARB ON IT FOR AIRCRAFT USE OR NOT?
AND IF YOU GUYS HAVE SOME INFORMATION ABOUT SUCH TYPE OF CONVERSION THEN TELL ME ABOUT IT
ANY SUGGESTION SHOULD BE APPRECIATED HIGHLY
WAITING FOR YOUR REPLIES
Falcons Cuz
spaceworm 04-21-2010 08:46 AM
RE: WHAT TYPE OF CHAIN SAW IS IT???????????????????
When you say "balls" do you mean the primer bulb that sits on the top of the carb? It is not necessary, but is helpfull to get fuel up to the carb. It really is not a primer, but just purges the air from the fuel line so that fuel is right up to the carb inlet. Lack of the bulb is not a problem. Good luck. (as an aside, typing in all capitol letters is like yelling and offends some people, just a friendly comment)
