RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   What size plane? (https://www.rcuniverse.com/forum/engine-conversions-92/9715194-what-size-plane.html)
hotelmode 05-06-2010 02:18 PM
What size plane?
I thought this would be a good place to post this, since these conversion motors weigh more than usual, and I'm sure some people here have experience on which planes to put them on.
I am in the process of converting a 30cc Homelite/Ryobi, and from the looks of it it should weight a little under 4lbs when I'm done with it. I got plans from Uncle Willie, http://*****************.com/about36.html, for the 60"-120" Das Ugly Stick. In the description, he has a rule of thumb that works out to a 1.20 size engine for the 120" span. The 30cc is 1.80. What size should I make it? I've only built 1 kit before, and never done one from scratch. I don't think 120" wings would fit in my car, unless I built them to come apart in the middle which I saw someone do on a build thread here, and it seemed to work out pretty well.
Thoughts? Suggestions?
Thanks!
w8ye 05-06-2010 03:06 PM
RE: What size plane?
A 80" span stick would be fine for your Homelite 30.
That's what I have mine in and it is just right.
hotelmode 05-06-2010 03:22 PM
ORIGINAL: w8ye
Sounds great, thanks for the quick reply. I might go with 85" just so mine is bigger than yours. HA!
<br type="_moz" />
w8ye 05-06-2010 06:40 PM
Sounds good
captinjohn 05-06-2010 08:11 PM
Mine will be 85 &amp; 1/2http://www.rcuniverse.com/forum/js/f...wink_smile.gif Capt,n
spaceworm 05-06-2010 08:24 PM
I am going to add extensions to my wing so mine is 86 inches span, but I have a 33 cc engine. :D
Bigger IS better. :)
w8ye 05-06-2010 08:35 PM
http://www.bridiairplanes.com/hangar/bridistick.html
http://origin-images.rcuniverse.com/...4/lg-12713.jpg
hotelmode 05-06-2010 08:49 PM
I want one of those, but they are out of stock. I emailed to see when they would be back in stock but haven't heard back from them.
w8ye 05-06-2010 09:07 PM
There two of these. The bridi Stick and the Old Timer. They are identical except for the name on the box. They are both out of stock.
Mine is about 9 yrs old now. I bought two kits at once. one of each. I still have the other kit. I had a Big Bee kit for several years and I sold it at a swap meet last year.
The Big Bee is much larger and would do better with a 50cc or bigger engine. It has a Kaos type wing and tail but a stick fuselage. When the Big Bee was designed, Joe Bridi had a Zenoah G38 in mind but you had better build it light with that small of an engine. A friend has one with a 80cc engine. It has plenty of power.
These pictures were taken in Colubus, Ga
http://origin-images.rcuniverse.com/...4/lg-38499.jpg
hotelmode 05-06-2010 09:09 PM
Is your other Bridi Stick/Old Timer kit for sale?
w8ye 05-06-2010 09:11 PM
I have a couple of converted Mac 32's, and I want to put one on the other kit some day.
