RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   ryobi muffler bolt (https://www.rcuniverse.com/forum/engine-conversions-92/9757297-ryobi-muffler-bolt.html)
michael wood 05-25-2010 12:12 AM
ryobi muffler bolt
I had a muffler bolt come out of my jag muffler does anybody know what size the muffler bolts are thanks michael
rangerfredbob 05-25-2010 12:40 AM
RE: ryobi muffler bolt
should be 10-24 threads, take the other one in to the hardware store to get a matching length one...
michael wood 05-25-2010 07:05 AM
thanks michael
mangolo 05-25-2010 03:43 PM
The two I have are 12-24
Waldo
Waco brotherhood #22
michael wood 05-25-2010 11:06 PM
I tried a 10mm and it did not fit think it was to big well i am going to a big hardware store and try and find one what i have is a jag engine 360 muffler i put lock tight on the bolts and they backed out so i guess i will use a washer and a split washer and lock tight michael
rangerfredbob 05-25-2010 11:17 PM
#10 not 10mm, #10 is about 3/16", #12 is just under 1/4".
w8ye 05-25-2010 11:21 PM
12-24 is hard to find.
michael wood 05-26-2010 09:24 AM
well i found a 12x24 screw its not a cap head screw but it will do i am going to put a split washer on it and lock tight it and hope it wont back out again michael
nitro joe 05-26-2010 06:29 PM
1 Attachment(s)
ORIGINAL: michael wood
Another option if backing out persists:
http://www.rc51.org/wire1.htm
Standard,or vice grip pliers will be fine for your two bolts.
Pay particular attention to the wire routing direction.
Look around the shop for a six inch piece of soft steel,light gauge,mechanics wire,or whatever small diameter stuff ya got.
michael wood 05-26-2010 07:07 PM
iam retired us army i was a flight engineer on ch-47 and know about safity wireing bolts that was one thing i was looking at but when i replaced the screw i could not find a cap head screw so drilling it is out now thank you michael
Flathead 05-27-2010 10:45 PM
I have a muffler that has been drilled to 1/4 standard, and it has a safety wire hole. I bought this engine from a swap meet and it was mostly junk, did retrive some good parts. Flathead
