RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   engine question (https://www.rcuniverse.com/forum/engine-conversions-92/9908448-engine-question.html)
rcairboater 08-03-2010 01:54 PM
engine question
If I convert my homelite 25cc engine and add a electronic ignition can I run the engine in either direction? Looking at the output shaft, I want the engine to turn right instead of left.
av8tor1977 08-03-2010 02:07 PM
RE: engine question
Yes. The only thing that determines which direction it runs is how you set the ignition timing.
However, you might have problems with the right hand thread crank nut coming loose. Depends on what you are going to do with it. Be very careful if you are going to put a propeller on it, as the engine pulses will loosen the right hand thread nut when running reversed, causing the prop to fly off. I haven't done a Homelite before, but on a couple of Echo engines that came with left hand thread cranks, I cut off the threads, and drilled and tapped the crankshaft for a right hand thread stud. You could possibly do this, but for left hand thread in your case.
McMaster Carr sells left hand thread taps.
AV8TOR
w8ye 08-03-2010 03:00 PM
RE: engine question
On a chain saw engine, the side the chain clutch goes on has left hand threads and the engine normally turns clockwise when you are looking at that side of the engine.
The 32 and 33cc saws are laying around like weed whackers are
Leaf blowers are often clockwise rotation also.
