RCU Forums
-   Engine Conversions (https://www.rcuniverse.com/forum/engine-conversions-92/)
-   -   Gear reduced starter insert???? (https://www.rcuniverse.com/forum/engine-conversions-92/9986206-gear-reduced-starter-insert.html)
av8tor1977 09-07-2010 12:39 PM
Hi guys,
I have a gear reduction starter that I think I bought from Central Hobbies but I can't be sure, but if it was from them they no longer carry it. Anyway, I need a new insert for it. The o.d. of the insert is 2". Anybody know where to get one??? I would prefer silicone if there is a choice.
AV8TOR
w8ye 09-07-2010 01:10 PM
RE: Gear reduced starter insert????
Hobbico cone http://www3.towerhobbies.com/cgi-bin...LXL403&P=V
5mm shaft hole with key slots for a spring pin
Rubber insert 2 3/16" diameter
http://www3.towerhobbies.com/cgi-bin...LXL404&P=M
av8tor1977 09-07-2010 04:30 PM
Hi,
Thanks W8YE, but I found those too. Too big. I would have to figure a way to shave the o.d. down by 3/16" to use the insert. Mine is right at two inches outside diameter for the insert. Can't seem to find one...
AV8TOR
w8ye 09-07-2010 05:00 PM
I thought maybe you could change over to that size being as they are readily available?
The standard small ones are 1 7/16"
You can buy a nice cone from Tower for the Tower starters that also is the same size as the Sullivans
Miller also sells small rubber inserts for Sullivan starters
Kimhoff 09-07-2010 06:54 PM
You probably have a Kavan starter.
About a 1/4 way down on the link below.
http://www.hobby-lobby.com/kavan_4169_mnf.htm
w8ye 09-07-2010 07:59 PM
http://www.hobbypeople.net/index.php...0-engines.html
av8tor1977 09-08-2010 10:52 AM
Thanks guys. Mine looks like the Magnum from Hobby People, but they don't list a replacement insert for it, much less the size.... [:o]
AV8TOR
av8tor1977 09-08-2010 01:27 PM
Just spent another couple of hours web searching. Cermark also has one that looks like mine, but no info on replacement inserts. I have e-mailed a couple of suppliers. Hopefully I can find one somehow.
I am actually considering greasing up the cone, filling it with silicone out of tubes, letting it dry and making my own insert!!
AV8TOR
w8ye 09-08-2010 02:15 PM
http://www.cermark.com/products/Alig...-HFSSTQ04.html
av8tor1977 09-08-2010 04:06 PM
Thanks, but yep, found that one too. They apparently only sell it with the whole bell, clutch, insert, etc. for 24 bucks plus shipping. [:o]
AV8TOR
w8ye 09-08-2010 04:13 PM
Typical hard luck story from that area . . . . Oh So Sorry . . . No parts . . . . . We sell you complete unit
av8tor1977 09-08-2010 04:39 PM
Yeah, it figures that I would end up with one that has an oddball size insert. Might have to go to a 3" bell like you said. It works pretty good. I have it set up with 14 3800 mah nimh batteries. It started my Echo 58cc single ok, and does really well on 20 to 45cc engines, but it won't start my homemade Echo 48cc twin cylinder engine. I think the batt's are getting a little tired though. I've been thinking of picking up a couple of cheap 2200mah 3 cell Lipoly batteries to run it. 14 of those nimh batteries weren't cheap!! But.... I need to find a new insert. Good thing all my engines start fairly easy by hand. I just like to have the electric starter as a backup in case one gets stubborn and I run out of patience...
AV8TOR
