Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Belt CP V2?
Old 12-16-2012, 01:59 PM
bayfire300
Default Belt CP V2?
Hi all,
A friend of mine gave me a big box of Heli stuff, a Honey Bee, Blade CP Lama and a Belt cp. Most of them have some broken parts on them but the belt cp
The belt cp is only missing the reciever, Is htis a good heli? it it worth getting a 72mhz reciever? It does have the speed controller and brushless motor on it
Thank you
Otto
Old 12-16-2012, 10:33 PM
phillyD
phillyD's Avatar
Default RE: Belt CP V2?
Hey Otto
I would not recommend the 72 Mhz, You should go for a 2.4 system. You may take some interferance and may lose the heli. Ther are enough reasons to lose a heli without adding that in the mix. I have two of them one regular and a night flyer
http://www.youtube.com/watch?v=pLyGi...cJ8zQ&index=51Since this the tail rotor is now lit
Old 12-17-2012, 05:01 AM
bayfire300
Do you reccomend a 2.4ghz system that is on the less expensive side.
Old 12-17-2012, 02:30 PM
phillyD
phillyD's Avatar
Sure I do. I have been using The DX6i for 4 years now with no problems.
Old 12-17-2012, 04:19 PM
bayfire300
Does that come w/ a reciever? I am not sure what servo goes where and also the gyro.
Old 12-18-2012, 05:42 PM
phillyD
phillyD's Avatar
Yes It does come with a receiver. The servos are out of of their slots? Take 2 pics of your bird one left side and one right side and post it here, I'll show you. I would be easier describing it to you. Elevator servo goes in the square slot.....Maybe I can take a few pics of mine.What type of servos do you have for it. i would not plan on using the ESKY servos for a long time.
EDIT Gyro is at the top of the frame at the back
ID:	1831701   Click image for larger version
Old 12-18-2012, 06:49 PM
bayfire300
I will take pics on thursday I am working 24 hours tomorrow.......but no all the servo's are in where they are supposed to be I just dont know what slot on the reciever each servo plugs in.
I think all that is missing is the reciever.......I found a manual online which told me where to plug each servo in on the original esky reciever but if i got w/ a dx6i I am not sure where each servo plugs in.
on a side note I see your from british VI...The US VI is my fave place .......spent honeymoon on St Croix and been there several times.....Wife,Daughter and I love scuba diving St Croix.
Thank for your help
Otto
Old 12-18-2012, 07:24 PM
bayfire300
Philly,
For now I think I am going to take the cheap way out and order a replacement (stock) reciever $10 bucks....Just to see if it all works....I have the transmitter so it seems obvious to go that route..........if it all works well I will go 2.4 w/ a dx6i
Then for sure I will be picking your brain.
Thanks for your help
Otto
Old 12-18-2012, 10:03 PM
phillyD
phillyD's Avatar
Great no problem
Just a side note, a lot of your answers to your questions and pics are in the Belt CP thread just below this thread. You can type searches there...i monitor that too. So if I miss it here...
Old 12-28-2012, 07:23 PM
bayfire300
Philly I got the reciever I am not sure where the servos plug in. In your pics the right side has two servos they got to 1 2 or 3? Th other side(left ) has 1 servo where does that plug in?
Also what position do they plug in I mean the 3 wires what orientation?.
Otto
Old 12-30-2012, 09:46 PM
phillyD
phillyD's Avatar
Hey bro Sorry Bout the late response, but I changed out my stock set up 6 weeks after buying my heli..that was 4 years ago...found the maual... #6 channel pit servo(right back servo veiwing the heli from the back) #2 channel elevator servo(front servo) #1 channel aileron servo(left back)#3 channel ESC #4 channel gyro #5 channel head lock)single wire.
Cheers
Old 12-31-2012, 02:20 AM
bayfire300
Great Thanks.. I will install that tomorrow..........I am waiting on main gears now i noticed they were stripped.
Otto
