Anyone using the flight sim that comes with the lama V4?
UT
If so can you give me a hand on setup. I checked their site but did not get much. Which heli are you using and whats your settings fir mapping? Thanks
CA
RE: Anyone using the flight sim that comes with the lama V4?
It is FMS right? When you set up your radio, just use the same value for the bottom 4 functions as you entered into the top 4. The bottom is really just a repeat, except they are for the Helicopter controls. Top is obviously airplanes. I have not used FMS for so long that I could not tell you the specific numbers to enter, just move the sticks on the radio and set accordingly....
Good luck.
Z
Good luck.
Z
UT
ORIGINAL: Zimatosa
Good luck.
Z
Good luck.
Z
KS
You have to enter the channel numbers into the spaces provided and check the inv on all of the boxes or try googleing fms transmiter setup
TX
When setting up FMS the seq for the boxes 42134213 then calibrate sticks, I'm using XP and TX has to be on before plugging USB in,then click on FMS icon otherwise for some reason it just fly's crazy
