Mystery 1500mah LiPo, anybody else waste some $$
NC
RE: Mystery 1500mah LiPo, anybody else waste some $$
ORIGINAL: DumbDawg
Catastrophic failure to the extreme on the scale of a small neighborhood sized nuclear weapon. Thats why you want your neighbor to solder them on for you while you and your family go several miles away to the local HS to buy some heli parts, body bags and a few AA batteries for your Tx at wallyworld.
Wish I could help but I've not had the pleasure yet to solder anything but connectors to a battery. You can't really hurt the battery unless you seriously short it out, then I would either run like hell or toss it like a grenade into the neighbours yard across the street. You didn't like them so much anyway.
happy fly'n
happy fly'n
CA
TFF!
I got a batteries where the wires broke off of because they were cold soldered. I peeled/cut the cover off at that end and resoldered them back on no problem, use a soldering iron about 50 watt max with a point on it, not a soldering gun just be careful working on that PC board you dont get solder on anything else or it will make a heck of a bang when it shorts out and lites up! If you dont have that large heat shrink to recover the end with use a few layers of electrical tape, It is not the preferred thing as the tape gets soft when it gets warm and my come off.
