Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Esky Helicopters
Reload this Page >
Belt CP V2 with Stock Tx
Esky Helicopters Discuss the line of Esky electric helis in here including the Honey Bee, Lama, Belt CP, etc
Old 06-07-2009, 06:08 AM
joeyhatch11
Default Belt CP V2 with Stock Tx
My Hov. Pit knob is ALL the way up and I need it that way just to get the heli off the ground. Being that she is flying now and doesn't sound like I'm pushing the motor to it's max when I have 50% throttle now, should I leave it alone or readjust it? If I adjustthe heliso I can turn down the Hov. Pit knob, how do I do so? Is my swash too high or too low? I know with the knob all the way up it raises the swash a good distance. Enough that when the knob is at 3/4 the heli no longer has enough head spin to lift. What do you guys think? Thanks, Joe
Old 06-07-2009, 08:04 AM
FLYGUY09
FLYGUY09's Avatar
Default RE: Belt CP V2 with Stock Tx
Joeyhatch11 - In normal mode (not idle up) disconnet the motor leads, apply 100% throttle & check the blade pitch. With the pitch knob at 100% what is your blade pitch? Just curious to see where you're at relative to full Hov Pitch setting.
The stock setting for the swash (at 50% Hov Pitch setting) is to be centered on the main shaft equidistant from the washout hub & the main shaft collar when you're: 1) in idle up mode at 50% throttle, or 2) in normal mode with 0% throttle. What are you seeing at either of those settings? Again, make sure the motor leads are disconnected when you do this.
Old 06-07-2009, 09:02 AM
joeyhatch11
Full throttle, Hov. Pit 100% I'm at +8. I double checked my pitch at 50% throttle with Hov.Pit at 100% and I'm at +3.  But with the Hov. Pit at 50% I have perfect 0 pitch. If I set Hov. Pit for 100% and drop my pitch to 0, will I be able to turn it down once it's reset?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
