Telebee setup problems
So i just got this new telebee gyro and i can't set it up!
i turn it on with out moving it at all i wait for the blue light to cme on when i throtle it up it just spins to the left the whole time i barely can move the rudder at all the only movement i can get out of it is when i apply full right rudder whats up? i am using a stock HBK2 with brushless a setup |
RE: Telebee setup problems
Hi,
I'm sure some other folks will come along and offer more help. I've never used the Telebee gyro but I did find this info that might be of some help to you. Skim over all of this stuff and see if anything jumps out at ya.: http://www.runryder.com/helicopter/t288540p1/ http://www.heliproz.com/images/wangtelebee.html http://www.ronlund.com/telebee_setup.htm Hang in there redbaron, you will get it worked out. Steve |
I had the same problem with my futaba gyro. What I had to do was flick the reverse switch on the gyro. This reversed the signals sent to the tail rotor servo.
What was happening was the signals sent to the servo to correct a left yaw were moving the servo arm in one direction to correct the yaw. But as the servo was mounted differently then what the gyro was set for it caused the tail to spin more to the left. If the servo was re-mounted back-to-front without changing a thing on the gyro then the signal would have corrected the yaw. Instead of re-mounting and flipping the servo back-to-front there should be a swith allowing you to reverse the signals on top of the gyro. Its marked by "Rev" on my futaba. Hope this helps and isn't too confusing... I feel my explaination could have been simpler. Let us know if it makes sense and if it solves your problem. |
i tried that but it didnt wotk
i found out that i had the gyro pluged into the wrong channel on the reciver |
so you have it working now??
yeah
but i cant get my blades tracked ive tried for hours nad they dont track. once they hit a cirtan rpm the go out of track |
ORIGINAL: redbaron9898 yeah but i cant get my blades tracked ive tried for hours nad they dont track. once they hit a cirtan rpm the go out of track |
| All times are GMT -8. The time now is 12:23 PM. |
