connecting an Esky 4in1 to spektrum rec..??
anybody know the hack to connect the esky 4in1 to a spektrum reciever ??...i have a DX7 on the way...want to make sure i get my HBFP working on it
any help is appreciated KC |
RE: connecting an Esky 4in1 to spektrum rec..??
I didn't know there was a hack to turn a 72mhz FM receiver into receiving/sending 2.4ghz signals... If you really want to use the DX7, I think you might be able to buy the receiver and 3 in 1 that the blade cp pro uses.
he'll be using a Spektrum receiver so basically use only the other half of the 4n1[by removing the RX part] and use mixer/gyro circuit board portion of it by opening the case and wiring the Spektrum RX like the Ar6100 as the receiver.
i am as well looking for a wiring diagram..i've seen it before here? but could not find it .. in my case i am planning to use the LP5DSM 2.4Ghz Transmitter[spare from a blade CX2] and a spektrum ar6100e Receiver board .... there is a dip switch on the LP5DSM TX that will change the mode from mixing 2 motors[for yaw] to just controlling a single[tail] motor for YAW...does anybody know w/c dip switch position that is? im going to use this for my EKSY HONEY BEE FP I also have the Blade Cp Pro 3n1 and can opt to use that instead for a more simpler mod. so anyone that has info on the LP5DSM mode switch let me know..thanks.. |
