speed control
hey guys
i have a belt cp and needed to change the speed control and noticed that the wire colour code is black red yellow on the new speed control compare to the black red white on the standerd speed any reason y new one is a dynam 45A |
RE: speed control
no special reason, it'll work just fine.
RE: speed control
sorry to steal your thead but i see you have a 45amp esc
can you use any amp rating and i will make no difference? so if i got a 40+ esc it would be no different to a 30a just more expensive? would it draw more power from the battery? |
RE: speed control
its cool
jip same thing the load it can handle would just be higer thow. woun't use more power. just more expensive like u say. low Amp esc are easier to burn out. |
RE: speed control
the biggest reason most don't use larger ESC's is cause they are heavier, thats all
| All times are GMT -8. The time now is 08:00 AM. |
