lama v4 - 4 in 1 controller
after a crash my v4's top blades kept turning full throttle. i disconected the battery and reconected it still the same. does anyone know how to fix this?
RE: lama v4 - 4 in 1 controller
do you have good batts in your transmiter?
have you tried adjusting the gain on the 4n1,also theres a way to reset the 4n1 if that doesnt work i read it somewhere but i dont remember how or where.try a search.,also is everything else working i had a glitching problem with mine and ended up being a bad crystal in the rx. lthough you may have the 2.4=no crytals :Dhope this helps. good luck
tried it and yes i have batteries
