Everything Diesel Discuss R/C Diesel engines here.
Box art and instructions / manual
Old 10-12-2010, 02:33 PM
gcb
Default RE: Box art and instructions / manual
Well, I got out the camera and 'puter for some stuff. Hope someone likes it...
The MVVS 2.5 on the right was originally RC. I made a "dump" type venturi for it (no sprinkler).
The significance of the Mills replica box is tha it is from the seventies.
The Rivers Silver Streak is original. I bought it back in the fifties.
More to follow...
George
ID:	1515407   Click image for larger version
ID:	1515408   Click image for larger version
ID:	1515409   Click image for larger version
ID:	1515410   Click image for larger version
ID:	1515411   Click image for larger version
ID:	1515412   Click image for larger version
ID:	1515413   Click image for larger version
ID:	1515415   Click image for larger version
ID:	1515416   Click image for larger version
ID:	1515417   Click image for larger version
Old 10-12-2010, 02:46 PM
gcb
More stuff...
I have more to resize and more pics to take.
George
ID:	1515422   Click image for larger version
ID:	1515423   Click image for larger version
Old 10-12-2010, 03:59 PM
gcb
More...
Apologies for poor pics. Some of the instructions are oil soaked and text bleeds through. Most of these engines/instructions/boxes are from the fifties. I haven't flown that Rivers since ~1965.
Whew!! That's all for now.
George
ID:	1515443   Click image for larger version
ID:	1515444   Click image for larger version
ID:	1515445   Click image for larger version
ID:	1515446   Click image for larger version
ID:	1515447   Click image for larger version
ID:	1515448   Click image for larger version
ID:	1515449   Click image for larger version
Old 10-12-2010, 04:44 PM
AMB
GCB-Interesting parts sheet, bolt on cylinder over liner sort of like MVVS and a little PAW thrown in too, My engine from that time period a Drone 29 fixed compression, looks like they were light years ahead on this one roller crank , nice carb, etc, etc Martin
Old 10-12-2010, 05:51 PM
gcb
ORIGINAL: AMB
I never had a Drone...always wanted one. A guy who ran them once told me that you would alter the prop size and ether content to adjust timing on the fixed compression ones.
If you look at the exploded view of the Silver Streak, note that both roller bearing and the crank are sitting in a sleeve. I understand you remove the entire assembly to work on it. I have never had reason to disassemble it. It only has a couple of hours on it. You need a pretty good size plane for it. Although it runs good, it is heavy. Last plane I had it in was a Flite Streak Junior (I've had half a dozen of them over the years), and it would not turn very tight. A Flite Streak or Peacemaker would fly much better.
George
Old 10-12-2010, 06:25 PM
  #31
AMB
GCB Thats bit of brilliant technology no gymnastics to pull a crank> It would cost tons of money to pull this concept off today, a real art of design and machining and from the 50's???
Looks like we have forgotten more than we have learned or just make is cheap as we can cut the corners martin
Old 10-12-2010, 07:45 PM
  #32
Recycled Flyer
Here is a brilliant site for infromation on the Rivers Silver Streak, and indeed many older engines -
http://www.the.elmores.btinternet.co...treak_am0.html
Old 10-12-2010, 08:02 PM
  #33
AMB
That explains it, they produced or made parts for full size engines, the crank thing they scaled down I believe this same technique is used in many other large shafts, thing the same principle use in large ship shafts they may go to 18 inchs or larger ,sectionlized just take out the bad one, put in a good one, rebuild (re-bearing it) and keep it for the next fix.they can do this at sea if needed of course the ship may have no power to the screw for an hour or so but no big deal till the section replaced ( think this a rare thing but they are prepared for it) or course if a twin screw vessel they keep going martin
Old 10-13-2010, 09:40 AM
  #34
gcb
ORIGINAL: Recycled Flyer
Thank you for the link RF. I think I just found out that my engine is probably not fully broken-in.
George
Old 10-13-2010, 09:50 AM
  #35
gcb
Today's first offerings:
One of the several Replica DEEZIL sources. The FROG 1.49 vibramatic I bought used from a friend in ~1965, while I was still in the Navy. It was well worn, somewhat abused, and the lower conrod bearing is a bit worn...but it still runs.
George
ID:	1515888   Click image for larger version
ID:	1515889   Click image for larger version
ID:	1515890   Click image for larger version
ID:	1515891   Click image for larger version
Old 10-13-2010, 11:31 AM
  #36
gcb
And the final entry for today is the Elfin B R 2.49. It is a reed engine. I bought it used, only to find that the ring that holds the cylinder on was cracked. I tried to repair it a couple of times to no avail. Guess I'll probably have to get a machinist to make me another. This may have been a common defect in this engine since shortly after I got it, the company made one similar but with (I think) a screw-on cylinder.
George
ID:	1515914   Click image for larger version
Old 10-20-2010, 12:26 AM
  #37
goggijo2
I've started to clean up the box illustration for the AM10. Maybe you could do a repro box with this ? If anyone is interested I'll complete and do the side labels.
John
Old 10-20-2010, 01:38 AM
  #38
DeviousDave
Christmas in October..... I got a package from Australia today!
These pics are as I opened everything up:
ID:	1519881   Click image for larger version
ID:	1519882   Click image for larger version
ID:	1519883   Click image for larger version
ID:	1519884   Click image for larger version
Old 10-20-2010, 05:49 PM
  #39
Recycled Flyer
ORIGINAL: DeviousDave
Hi Dave,
I see that Dave Owen is back from Europe with the last of the Schlosser's and I don't think that there will be any more made, ever, so this is the last of them.
Back on topic - treasure Dave Owens instruction sheet, it is far more pertinent than any factory directions and I have one for the MP Jet that just seems to make better sense than the Czech translation that comes standard with it. (But I must admit that my Australian MP Jet instructions are far more detailed though.)
Old 10-21-2010, 01:04 AM
  #40
DeviousDave
Hi Dave,
Yes, this was from the last run. What he has on hand for stocks will be the last ever. He didn't get any more spares while in Germany (the engines were delivered in Oz just after he left). I am not sure what his current Schlosser inventory is for parts or engines, but I think he has more engines.
On a positive note, this last run was a break from the norm in that the engines all came with exhaust collectors-even the .25cc.
On an even more positive note, I had a bunch of spares ordered for the MP .061 BB Jet diesels that he was mostly able to fill from his stocks. He inquired at MPJ and got a reply today that everything on my post-order wish list (save new engines) was going to be included in his next shipment from MPJ!!
Guys, if you want a Schlosser of your own or spares for MP-Jet engines, I wouldn't wait. He's really nice to do business with too-very responsive and good for his word.
Old 10-21-2010, 05:06 PM
  #41
Kiteflyer
My Feedback: (17)
Hi Dave,
Recycled flyer, i think the instruction sheet is the work of Benno or someone else, not David Owen. I got my engine, with the kind assistance of an intermediary in Germany, directly from Benno and it is supplied with the same two sheets of instruction that Dave has posted photos of.
Their is no reference to Owen on either of those sheets, alluding to Benno instead. Under the "fuel" heading, "kero" is replaced with "petroleum" with the addition of "Do not use synthetic oils" in the photos while the correction and addition is missing on my sheets.
Old 10-21-2010, 05:49 PM
  #42
Recycled Flyer
ORIGINAL: Kiteflyer
Hi Dave,
Ok, I must have assumed that the 'Dave Owen' stamp in the upper right corner of the short instructions were his.
With my MP JET I recieved some Owen based instructions that were very detailed and when I saw his stamp on some paper work I jumped the gun back there, oh well!
Cheers mate.
Old 10-22-2010, 12:45 AM
  #43
DeviousDave
My .25 came directly out of Benno's hands via RocketRob and they are written in English. Someone else had to have written them for him but I don't know who-Benno had to have orders and inquiries transcribed for him when he sold engines and Rob had to have two interpreters with him. Rob probably babbled and drooled enough that two were neccesary!
Old 11-02-2010, 01:02 PM
  #44
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
2nd try on Davis instructions
ID:	1527237   Click image for larger version
ID:	1527238   Click image for larger version
ID:	1527239   Click image for larger version
ID:	1527240   Click image for larger version
Old 11-26-2010, 06:39 AM
  #45
gcb
For those who like David Andersen engines:
George
Old 12-02-2010, 07:02 AM
  #46
gcb
Here is some info on the requested FROG 2.49. I have three of them and after looking closely at the one I took pictures of, it is one I bought new back in the fifties and it has two non-standard repairs on it. The tommy-bar wire broke and I put a new wire in it using epoxy, and the needle is a WEBRA generic replacement needle and spraybar with the needle wire clipped for protection.
George
ID:	1529248   Click image for larger version
ID:	1529249   Click image for larger version
ID:	1529250   Click image for larger version
ID:	1529251   Click image for larger version
ID:	1529252   Click image for larger version
ID:	1529253   Click image for larger version
ID:	1529254   Click image for larger version
ID:	1529256   Click image for larger version
ID:	1529257   Click image for larger version
Old 05-11-2015, 06:46 PM
  #47
fiery
Allbon Javelin 1.49 c.c Mk 1
ID:	2095447   Click image for larger version
ID:	2095448   Click image for larger version
ID:	2095449   Click image for larger version
Old 08-29-2015, 08:28 PM
  #48
GLbiggles
George
I have some new Frog 1.49 conrods and heads.
