Everything Diesel Discuss R/C Diesel engines here.
PAW 19 what to build.
Old 04-22-2011, 06:13 AM
nitroairplane
nitroairplane's Avatar
Default PAW 19 what to build.
Hey i recently purchase a PAW 19[3.1cc] non throttled engine i will send it back to the factory soon so that they can add there carb but what i want to know is what should i build for it i mean i would like a nice high winged vintage plane but i am open to any suggestions you guys might have.
Thank you,
nitoairplane.
Old 04-22-2011, 02:29 PM
earlwb
earlwb's Avatar
Default RE: PAW 19 what to build.
I would go for a Coroplast Delta plane. You don't really need a throttle. You can use a fixed fuel pickup or a servo operated fuel cutoff device, if you really want to be able to kill the engine for some reason.
Around 20 to a 24 inch wingspan should do the trick. look for a coroplast election campaign sign to scarf up and you are in business.
You only need elevons so that is two servos with mixing for elevons.
Old 04-22-2011, 03:17 PM
Augie11
I have a PAW .19 on a Hal DeBolt Livewire Champion. Perfect match.
Old 04-22-2011, 03:53 PM
mike109
mike109's Avatar
G'day. I used to fly a Sig Kadet Seniorita with a PAW 15 RC engine. It was great but a little more like your 19 would have been good in windy conditions. A friend talked me out of it and so now I am considering getting another kit and building it for the engine (or perhaps making it electric.).
To keep it lighter, and to avoid the problem of covering lifting round the front of the plane, I simply doped the front section then painted it with several coats of clear lacquer. The rest was covered in film.
Enjoy your PAW.
Mike in Oz
Old 04-22-2011, 04:50 PM
AMB
Well at least I have the PAW 19 got in a swap for an electric ARF and it was old brushed 400 ok flyer however martin
Old 04-23-2011, 03:37 AM
nitroairplane
does anyone know where i could get a cub in the right size for this engine?
Old 04-26-2011, 04:35 PM
Recycled Flyer
ORIGINAL: nitroairplane
Hi mate,
Please define what a 'cub' is and you may get an answer.
Thanks.
Old 04-26-2011, 05:14 PM
AMB
The only "cub" I know off is the J-3 Piper cub which I think came out in the late 30s, high wing 2 seats one behind other . Power opposed 4 lycoming 65hp; As kid got about 15 or 20 hours in one. One day flying in a 20 mph headwind airspeed 65mph groundspeed 45mph cars were passing us on the hiway below martin
I WAS A BAD BOY flew it under the Goethels bridge linking New Jersey with Staten Island a borough of NYC, the flight instructor was not a happy camper
now back to this guys question I Have a Nitroplanes j-3 cub 49.6 inch span MVVS 15 diesel in it they list 15-25 glow engine as suitable power the 19PAW should be fine with RC CARB
Old 04-26-2011, 05:46 PM
earlwb
earlwb's Avatar
AMB, the OP id in the UK. So even if Nitroplanes had any instock, it wouldn't do him any good. He needs a UK source.
The only thing I can think of, is maybe there is still time to make the Middle Wallop Vintage Swap meet and check things out.
http://www.rcgroups.com/forums/showthread.php?t=1429492
Old 04-26-2011, 05:51 PM
AMB
EARL whoops MISSED THAT Ripmax may have one or a similar airframe of Brit or Euro heritage pretty basic type THX for catching that martin
mike pointed out Senorita good choice too if you can get it there
Old 04-27-2011, 11:07 AM
nitroairplane
That is the main problem i come across it is hard to find specific things in the UK i find nice modes all the time they are just never what i am looking for at the time that is why i build from plans a lot and yes that nitroplanes is pretty nice.
