Need a little p.a.w. advice
RE: Need a little p.a.w. advice
ORIGINAL: whoopee
well finally got around to running it again today and she got tighter so i took her apart again and the hole in the center of the crankshaft aint a circle and the pin will move up and down with stiff finger pressure. qazimoto you were right i dont know how i didnt catch that at first but i didnt.
Thanks you all. Do any of you know if the cranks in the current production .09 will fit a mk1 09??
Whoopee
Whoopee
I believe that the shafts from the newest 09's will fit the early ones. I might add that the later mk2 bluehead that I also own is an excellent little engine.
Good luck, Ray
