Everything Diesel Discuss R/C Diesel engines here.
Super tigher 3000
Old 03-29-2015, 01:30 PM
erik58
Default Super tigher 3000
Hello- I would like to know if it is possible to put a walboro. Or a zama carb on a conversion engine? Will it pass the fuel? I don't have the original carb for it . Do have to put a pulse line on it? Any help would be great help thanks Erik
Old 03-30-2015, 03:53 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It will require a pulse source, the closer to the carb the better, check out the way MVVS did it. Either brand will pass fuel. Here is mine with a SuperTigre 2300 carb.
Name:	SuperTigre 3000 Diesel 001 (Small).jpg
Old 03-30-2015, 02:50 PM
erik58
Thanks for the info. Erik
Old 04-03-2015, 06:12 AM
dennis
My Feedback: (90)
There was a conversion for the ST300 a few years ago. Basically it was a nylon base plate made to accommodate a walbro carb with the pressure source built into the base. I believe it was from CHS in Wyoming but doubtful that it is available anymore. From all accounts it was a great conversion and when coupled to a cdi unit made a perfect conversion.
With a diesel conversion I think you would need a carb from an 80cc weed wacker.
Dennis
Old 04-03-2015, 10:18 AM
erik58
I'm going to make my own thanks every body for the info Erik
