DC Dart .55cc Marine
Hello,
i have a little Dart Diesel Marine of .55 cc displacement. Is anyone familiar with these and have ideas on size of boat, prop and what hardware to make the connection. I have a carb from another .5 cc diesel I can adapt so I can have throttle. I posted this in the boat section but not getting any replies.
DC dart marine and aero
DC Dart marine .55cc
Thank you.
Thank you.
Hello,
Thank you.
Thank you.
Here is an old link to RC User's Group I the boat section that has an engine similar like yours:
https://www.rcgroups.com/forums/show...se#post3215418
Here is another link that probably get you more help there than anywhere else. Since you have an old British diesel engine.
You will have to sign up to join into the group, but they will give you all the info you will need.
https://www.modelboats.co.uk/forums/
I can give you a starting point?
A "Vee" hull design (like a bass boat) with a length between 14 to 18 long with a beam width between 6 to 7 inches.
Two blade prop size between 1½ to 2 inches with a pitch 1.25 to 1.50
The smaller the boat the faster it will be. The larger the boat the slower it will be ( but able to handle choppy water better).
sosam117
Mike Mac
