New to Diesels
Going to give diesels a shot. Looking to buy a new PAW 0.09 RC engine and a suitable plane. Maybe build one of the plans on Doctor Diesels website. For the fuel, looks like we have K1 Kerosene at the gas station, Amazon has John Deere starting fluid, and castor oil from Sig Models.
New guy, the PAW's are solid engines that will serve you well. Go to there website they have videos on setting up there engines. If you buy one new don't play with the compression setting as they run them before they leave the factory and have a good starting compression setting. For fuel with the smaller engines start with 40% ether (JD starter if you can), 25% total oil (could be 50/50 castor/syn) 33% kero and 2% Amsoil Cetane Improver. The 09 will be happy starting with around an 8x4 prop after break-in you could drop to a 7x6. One tip - don't use an electric starter as they can bend connecting rods on diesels, also don't over prime, just a couple choke pulls through of the prop and its ready to start.
It should be possible to order engines direct from the factory in the UK. I've sent engines there for rebores in the past with no problems. Eric Clutton (Dr. Diesel) is getting on in years and is doing less these days.
