45% ether??
Hello All:
I recently purchased two MVVS Diesel engines. They are a 1.5 and a 2.0 cc in size. The instruction that were included with the engines specified a 45% ether content in the fuel. Why does MVVS state that such a high percentage is required? I have not tried this mix yet as I have been running a 30% mix of ether. Would 45% ether make starting easier?
Tia,
Franchi
Tia,
Franchi
I have read that also and in the light of what we know the 45% mix would be a waste of ether, furthermore I would venture to suggest that the ingredients listed would be more for local consumption (in the Czeck republic).
I would use 30 ether, 45 kerosine and 25 castor (not synthetic) and have done so for both the 1.5 and 2.0cc engines. It isn't rocket science.
Ployd in OZ
Ployd in OZ
The engine will make less power. It should however start easier and throttle better if R/C equipped. The old Drone engines with their fixed compression heads ran a mixture of ether and IIRC 70wt oil only. No kerosene. Not very powerful, but they ran.
Hello All:
Tia,
Franchi
Tia,
Franchi
Hi Franchi.
I have never used 45% ether in my fuels but do use 30% in my 0.25cc engines only as they require a bit more help to start. For sure the engine will start easier (for a beginner) but if you read your instruction sheet you will see a second fuel formula for general running which recommends Amyl Nitrite as the ignition improver.
Personally, for running in a new engine the tried and true 33/33/33 mix is the way to go then switch to less caster and ether and more kero.
Ployd in OZ
Ployd in OZ
Hi Franchi.
Ployd in OZ
Ployd in OZ
Amyl Nitrate is not easily obtainable in the USA; most guys here that mix their own fuel use Amsoil Cetane Boost which is 2-ethylhexyl nitrate which is very similar to amyl nitrate. I have a small bottle (12oz I think) that will last for a LONG time. 2% in a quart amounts to about a capful or so.
Amsoil apparently works just as well as a Cetane Booster, according to locals who have tested both it and Amyl Nitrate, so there's no need to use the others. Amyl Nitrite needs to be be used in higher percentages to be an effective DII. It was quite easy to get when I was a kid.
