Everything Diesel Discuss R/C Diesel engines here.
Magnum .15 Diesel ?
Old 04-14-2004, 08:04 AM
Default Magnum .15 Diesel ?
I saw a Magnum .15 r/c the other day and I was intrigued. Twin needle carb, ball bearing, only 6.5oz, $45.00 and "tight" ABC. I called Davis and he said "NO". The bore on this engine is 15mm. The bore on my FOX .15 is .590" (14.986mm by my calculations). Would the FOX diesel head fit? Any body put a homemade head on a Magnum .15. My FOX .15 is a great Diesel but it is 7.8oz and $65.00.
Francis
Old 04-14-2004, 11:08 AM
DesignMan's Avatar
Default RE: Magnum .15 Diesel ?
You can get a head for the Thunder Tiger .15, it is very similar to the Magnum, but DD makes a head for it. I have one, just broke it in on glow and put the DD head on it, but haven't had a chance to run it since.
Old 04-14-2004, 04:06 PM
Motorboy's Avatar
Hi, i has a Magnum XL 25 Diesel, and the cylinderhead are machined of me with my own lathe and dividinghead.
Jens Eirik
ID:	122238   Click image for larger version
ID:	122239   Click image for larger version
ID:	122240   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
