Everything Diesel Discuss R/C Diesel engines here.
Diesel Plumbing??
Old 04-26-2004, 08:58 PM
Tim Wiltse-RCU's Avatar
Default Diesel Plumbing??
Ok guys I'm off to get started on my first diesel. What type of fuel lines will work with diesel fuel? This is a DDD Cox conversion.
Take care,
Tim Wiltse
Old 04-26-2004, 09:49 PM
Luftman's Avatar
Default RE: Diesel Plumbing??
Tygon or Neoprene will work. Anything that works for gas will work, your local shop will have it.
Old 04-26-2004, 09:57 PM
Your local hardware probably has tygon tubing for gasoline in the small size you need.
Jim
Old 04-27-2004, 06:50 AM
DUBRO DUBRO DUBRO
Automotive neoprene is somewhat stiff for fuel tank use. DUBRO neoprene (especially older packets are good and flexible).
Francis
Old 04-27-2004, 07:33 AM
gcb
Don't forget the plumbing inside the tank if you use a plastic tank. Also the fueler. If you use the Pylon type, be sure to get a diesel one.
George
Old 04-27-2004, 10:06 AM
That's the one with the black bulb for gasoline; works fine. Even better for your use is a Norvel all plastic syringe.
Jim
Old 04-27-2004, 03:56 PM
DesignMan's Avatar
www.smallparts.com for Viton tubing. Everything proof at high temperatures. And cost to match!!!
Old 04-30-2004, 04:47 PM
My Feedback: (10)
Tim, I have a part roll of the small diam Dubro neoprene (not made any longer) if you want a hunk let me know I will mail you a piece.
AJC (see I hang out here too )
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
