Stuck Contrapiston?
RE: Stuck Contrapiston?
One run of the VA miniature Elfin 1.8s came with extremely tight contrapistons. I had to press them out using a vice with wooden blocks and a dowel. Then I polished the contrapistons, cleaned them and re-fitted them. I still left them fairly tight and they freed up with use.
That engine is not difficult to start but requires a technique of 'catching' the engine by advancing the compression immediately it starts running.
I had an unusual problem with some VA Micros a while back - 1 run of these came with contrapistons that were too long. These had to be shortened before it was possible to run the engine. No big deal but tiresome.
I hasten to add that I have not had these kinds of problems recently with VA engines.
Incidentally George Aldrich did not always work on these engines himself - he had some sent to me!
Depending on what you mean by a push fit, you may end up with a sloppy contrapiston. I think if you can push one into place with your finger, it is likely too loose.
ORIGINAL: Jim Thomerson
Jens Eirik
Dave,
How do you "Polish" your contra-pistons and keep them perfectly round? What is the setup you use?
The drill press method George described sounded good to me as it would lap the CP to the cylinder.
I got my mini-Elfin 1.8 from Neville Palmer when I made a run of boxes for him. I also made some for you, maybe on Mini-Mills or Kalper, can't remember.
There is no way I could do the quick compression adjustment on the Elfin as the lever will not move the CP the way it was delivered.
For My own engines I did the boxes in color.
#31
TX
Mr. Larkin
I have a VA 0.4 cc Mills replica engine, but it is missing its thrust washer (betweenrear face of prop and front face of crankcase). The crankshaft is tapered conically from the front faceof the crankcase,down to the +/- 2mmthreaded crankshaft.
Do you by chance have this part, and if so will yousell it to me?
Thanks verymuch,
William Hanshaw AMA 31631 [email protected]
Thanks verymuch,
#32
William,
You have awaken a thread that had died nearly six years ago...
Mr Larkin has last posted here, in RCU, in 2008 and has not been overly active in any case.
I wish you luck getting answers from him.
#33
TX
Mr. Larkin,
Would you happen to have some spares for the VA 0.4 Mills Diesel replica engine?My little diesel is missing itsthrust washer. I understand that VA has been out of production for some years and can't be contacted. Your kind assistance would be appreciated.
Thanks in advance,
William "Bill" Hanshaw AMA 31631 Fort Worth TX
Thanks in advance,
