Everything Diesel Discuss R/C Diesel engines here.
Taplin Twin
Old 03-01-2013, 01:44 AM
classicracer
Default RE: Taplin Twin
I recently purchased a MKIII Taplin twin. It is NIB. I would like to run it on my test bench, as I do with all of my engines. I am planning to build a '40/'50s design airplane around it. Any suggestions?
Old 03-01-2013, 11:30 AM
brokenenglish
There are very many choices:
KK Falcon, BB Majestic Major, HV450, etc.
The Radio Queen flies particularly well with a Taplin Twin.
Note that the aircraft mentioned all have upright engines.
When you use a nice old engine (including Indian production), it's nice to actually see the engine, and not have it buried inverted, inside the cowling.
Old 03-01-2013, 01:32 PM
fiery
Classicracer
There should be a spiral wound spring under the main needle to maintain tension. Yours appears to have a second nut added to act as a lock nut, presumably to prevent the needle wandering.
A suitable coil wound spring should be easy to fabricate or locate.
Your engine appears to be an early Aurora production. Does it have "made in England" stamped on the top of one of the mounting lugs?
Regards
Old 09-04-2015, 02:52 AM
jimmy-44
HI FOLKS
My TaplinTwin Mark1 are doing well in an old Swedish boat named BRIDGE from the same year 1958
The other diesels are Enya 15DII .Frog 349,K/B converted to teamracerdiesel and The Russian MK-17
//JIM
Name:	2015-05-27 19.57.54.jpg
ID:	2118026   Click image for larger version
Name:	2015-05-03 14.20.40.jpg
Old 09-04-2015, 05:15 PM
earlwb
earlwb's Avatar
I put my Taplin Twin in a House of Balsa Petenpol at the time. It was a great combination too. The engine was amazingly quiet too. Once airborne it was more like flying an electric motor powered plane. So I would suggest something along that line. Maybe a Bleriot for example or something similar.
Old 04-24-2020, 08:24 AM
  #31
Mike_frear
Default Taplin
Hi
Has anyone got a Taplin for sale?
Regards Mike
Old 09-24-2020, 01:50 AM
  #32
123Cat
Default Fiery
Well done with the video's, it feels like its
Have to be more careful
my own motor , General Taplin will be proud of you
and that cabin cruiser , to die for
Could never build a nice boat like that
Here is a picture from my last outing with my son , we had a good time
