Overheating Diesels?
I was reading a review on a diesel MVVS 2.5 engine that stated it was relatively tolerant of overheating. My questions is how do you know if the engine is overheating? There was no mention of cylinder head or exhuast gas temps. What signs to look for?
Greg
Greg
I have lots of diesels ave not seen any overheat thing I did reach 235 degrees at head cylinder junction on one, I would imagine you could do it by severe overcompression or lack of cooling air in a cowl , most of mine you can touch you hand on the muffler for a short time and on some hold it (DO NOT DO THIS ON A GLOW ENGINE YO WILL GET A NASTY BURN) In reality you sometimes have a problem keeping it warm enough sometimes at low speeds. You can hold you hand in the exhaust, I do this all the time to make sure
oil is coming out its only warm. If your fuel is wrong low ether, and over compressed it might get hot martin
if you look in the exhaust stack of a glow enine no muffler you will see a blue flame none in a diesel
My Feedback: (102)
Greg, there is a difference in the way the engine heat is distributed over the engine, my Fox .74 for example runs on glow with the crankcase almost cool and the cylinder hot. On Diesel it runs the same temperature all over, I can only assume that this is because there is no methanol evaporating in the crankcase. It does not run hot though.
TX
My MVVS 2.5 did run very hot for about the first gallon
and then quite suddenly began to behave.Probably if I
had run the 40% ether like they reccomend it would not
have exhibited the over heating during break in period.
I have one that is nib and will try it like the factory says
and get back.
Ralph
and get back.
Ralph
ORIGINAL: mylamo
and then quite suddenly began to behave.Ralph
Jens Eirik
MVVS makes excellent engines.
As for break-in, ever since I came upon this site I have broken-in my diesels as they recommend:
http://www3.bc.sympatico.ca/dieselcombat/index.htm
George
George
