Everything Diesel Discuss R/C Diesel engines here.
What planes are your Diesels in?
Old 12-24-2013, 12:38 PM
  #151
brokenenglish
It's late Christmas eve here, so I ain't gonna scan this evening, but I'll do it tomorrow if fiery doesn't do it first!
We're celebrating Christmas, but just before I fell off my chair, I realised that ol' fiery has been misleading us with the name "Mills Bomb".
The "Mills Bomb" was a forties English control liner, one of the very early ones.
This David Boddington design that we're discussing is called the "Mills Beam" (I think). As I said, we're celebrating, and that's only from memory, but I think I'm correct...
Anyway Happy Christmas to all diesel lovers!
Old 12-25-2013, 04:21 AM
  #152
PWF63
PWF63's Avatar
2314 Christmas night here. Hope all the Aussies here had a good Christmas day.
A merry Christmas to our modelling friends just starting the day.
I had to come to Fiery's defense here. Sorry Brokenenglish but the model is the Mills Bomb.
Featured in Aviation Modeler International March 97.
Old 12-25-2013, 04:24 AM
  #153
brokenenglish
Thanks, I'll look mine out...
OK, maybe the same plane has been published with two different names...
I just googled "david boddington mills beam", and I got a lot of results, so the boddington Mills Beam obviously exists (I have the plan!)
I'll have to dig through my plans.
Edit:
According to info on the Web, the DB Mills Beam was published in RCM&E March 1988. That must be the plan I have. From memory, it's exactly like the plane in fiery's photos.
Old 12-25-2013, 11:06 AM
  #154
PWF63
PWF63's Avatar
Here's rest of the MB article Brokenenglish. I know that Boddington did the MB for the Irvine Mills 1.3.
Article on this engine in same mag MB Pages 36-37.
Will be interesting to see your documentation on the Mills Beam. Boddington do do a lot of models. He might have done 2 the same.
Cheers
Fredo
ID:	1951232   Click image for larger version
ID:	1951233   Click image for larger version
Old 12-25-2013, 12:37 PM
  #155
brokenenglish
Yeah Fred,
I've found the RCM&E with the Mills Beam in it. I'll post it shortly. It's kinda coming back to me now. Sadly, neither David nor Ron (Moulton) are around for me to ask...
In 1988, David designed a "quick & simple" plane for the new Irvine Mills 75. That's the Mills Beam.
As I remember, in the early nineties, David left ASP/Nexus following a "financial disagreement" (I had conversations about that with both David and Ron), and he joined the rival publishing house, created by Tony Dowdeswell, as Editor of AMI.
So when Irvine released their Mills 1.3, David saw no reason not to rehash his Mills Beam design, but this time for the 1.3. This was done and published as the Mills Bomb.
I'd forgotten about this. In my mind, there was only one plane (I think they're virtually identical!).
OK, I'll get scanning!
Brian
Old 12-25-2013, 01:03 PM
  #156
brokenenglish
OK. Attached are the two centre pages of RCM&E March 1988.
This is the entire (brief) write-up of the Mills Beam.
The fold-out free plan (which I have) was inserted between these pages.
Looks to me like the Mills Bomb is possibly slightly bigger...
Name:	Mills Beam002.jpg
ID:	1951257   Click image for larger version
Name:	Mills Beam001.jpg
Old 12-25-2013, 06:04 PM
  #157
PWF63
PWF63's Avatar
Thanks Brian
Now we're all the more educated with this information. I was going to build the Mills Bomb for my CS Bodo Mills 1.3 but
I do have a Mk1 Irvine Mills .75 that I might build the Beam for.
Would you please let me know the span of the Mills Beam and If its smaller than the Bomb I can get my plan scaled down a bit.
The Mills Bomb is 35" span.. They definitely are identical models though to look at.
Cheers
Fredo
Old 12-26-2013, 02:23 AM
  #158
brokenenglish
OK, as you can see, the Mills Beam article title states 31" span, but the title block on the actual plan states 32", so you can take your choice, or fudge somewhere in between, or I can measure the plan, or I can just try to scan the plan and post it...
Old 12-26-2013, 12:58 PM
  #159
FSII
Hi Guy's I'm the builder and owner of the Mills Bomb referred to by Fiery, I go by the handle of Red Zephyr in another forum.
FWIW I've now built 4 Mills Bombs, they've all been 3 channel RC (Throttle Rudder and Elevator) the first was powered by an unreliable Enya 09, that along with some poor wood selection saw it eventually go to Mills Bomb heaven, the second was originally built for Electric power using a 3S1P 1300mah lipo, I built it as a park flyer when I lived in Sydney (Australia), I scrapped it due to some fatigue issues with the "fuse" structure, the third (in Fiery's photos) was the second fuselage rebuilt in a hurry to get my PAW 1.49 in the air and get some ether fumes lurking in my lungs again, this one become oil infused and at one point at home fell apart in my hands. Yes I do have a fourth but have yet to "post build" test fly it, Oh, I used the same wing for the first 3.
As Fiery says, I made a small change to the original plan (apart from making it 3 channel) in that I extended the wing span by making the section of wing that sits over the "fuse", I did that to make a bit more room internally.
I see there is a bit of conjecture about the wing span, the plan that I have says it's 35 inch, I've taken a photo which I'll attach along with a few more pics of MB III. I'll drop the plan into Fiery next week for him to copy.
Cheers
ID:	1951470   Click image for larger version
ID:	1951471   Click image for larger version
Old 12-26-2013, 10:55 PM
  #160
brokenenglish
Default Mills Beam again!
For Fred and anyone else interested, here is the 1988 Mills Beam plan.
You should be able to get something buildable from these scans.
So we now appear to have just about everything.
The Mills Bomb looks like a quick 10% enlargement on the photocopier!
David was always very active and busy, and sometimes had problems meeting the publishing deadline...
Name:	Mills Beam006.jpg
ID:	1951594   Click image for larger version
Name:	Mills Beam003.jpg
ID:	1951595   Click image for larger version
Name:	Mills Beam004.jpg
ID:	1951596   Click image for larger version
Name:	Mills Beam005.jpg
Old 12-27-2013, 10:04 AM
  #161
jjscott
jjscott's Avatar
Thanks to everyone for the complete information on the Mills Beam/Bomb.
Jim
Old 12-27-2013, 08:02 PM
  #162
wnewbury
Had a PAW 19, from Carlson in Arizona, in my Trenton Terror old timer. Really liked it but it was difficult to get fuel. Just recently ordered some Davis fuel from Tower so maybe the PAW will get used again.
Old 01-01-2014, 04:08 PM
  #163
triumphman49
My Feedback: (149)
Hi all & Happy New Year ! ! !
Rare poster in these forums and first for these diesel threads, . . . . but did have a couple of querys for answers or advice.
BTW Hobbsy, how is your Saito "diesel" doing ? Is it the .80 size?
Have a few DDD heads, but have only run one 40FP (in a Kyosho Cub) , . . . . spun a 12" prop well, and looking for possibly another one for an OS32. Haven't decided yet about my K&B Sportsters, as they already spin a good size prop, but my Dynaflite big Spit is a toss up between the OS1.08 and my CDI converted Saito 150.
My main query concerns a NIB MVVS 120 twin. Bought a MVVS conversion head for my .77, . . . . and then read where it didn't make as good a conversion prospect as there .61. BUT , the 1.20 sits looking at me.
Been in touch with Dar Zeelon (rep),who gave me a factory web address, which I've also used to no avail, in attempts to locate another matching factory head, but to no avail. Might anyone here in "DIESELAND" have a lead in attempts to find another MVVS .61 diesel conversion head ? ?
Thanx in advance for any input & again, Happy New Year ! ! !
T-man49 in Alabama
Saito #723
Spitfire Bro 19
"ROLL TIDE"
Old 01-01-2014, 04:27 PM
  #164
AMB
Try Davis diesel not its listed on the site anymore, but may have one on the shelf ( if you have not done so) regards martin
He never made a77 head 61 yes
Old 01-01-2014, 04:53 PM
  #165
triumphman49
My Feedback: (149)
Hello Martin and thanks for the quick response.
Have checked the parts breakdown per the PE Rievers (sp) site, and beleive they share the same head .
May give him a call, tho, am hoping for a factory head with the T-hdle.
Again, many Thanx for your interest
T-man49 in Al
Old 01-01-2014, 05:06 PM
  #166
AMB
never knew they ( MVVS) had a 77 diesel head I have the 40 and 61 which I changed over to the Davis ones martin
whoops wrong pix
Old 01-01-2014, 05:27 PM
  #167
triumphman49
My Feedback: (149)
Hey again Martin
Sorry bout the confusion, . . . What I have is a MVVS conversion head for the .61. As they both (the .77 and the .61) seem to share the same head, . . . . . . . , I entered my bid, and bought it.
T-man49 in Al
Old 01-01-2014, 05:36 PM
  #168
AMB
Triumphman 49 good show glad you got it I did no know the same head was shared on the 61 and 77 martin
Old 01-01-2014, 05:39 PM
  #169
AMB
not good news Pe Rieverss passed a few months ago bought a number of engines from him a while back martin
Old 01-02-2014, 01:54 AM
  #170
triumphman49
My Feedback: (149)
Yes, terrible news that took by surprise. Always admired his demeanor, and tried to learn what I could from his post here and elsewhere.
T-man49 in Al
Old 03-15-2014, 03:07 PM
  #171
[email protected]
Default Playboy Cabin
I built a full size Playboy Cabin from a Holman short kit in 1999. Started life with an Oliver Jaguar/Panther 2.5 cc diesel reproduction. Also flown with a GB 5.4 cc diesel and others. Even flew with electric power. This year I thinned out the herd and gave the Playboy away. I live in a small apartment and not a lot of room for models. New owner built a new fuselage with pylon and Fox .35 stunt for the SAM FoxaCoy event. Jack
ID:	1978285   Click image for larger version
Name:	Playboy with Jag.jpg
ID:	1978286   Click image for larger version
Name:	th_Playboy with GB.jpg
Old 04-23-2014, 07:43 AM
  #172
telmore
I have a CS Rivers in a KK Firebird.
A CS Tiger in a Hallam combat wing.
A PAW 15TBR in a Brodak Lightning Streak.
A PAW 19TBR in an unknown combat wing.
An Enya 15SS in a Flingel Bunt(pictured).
A Parra 2.5 in a Billy Bunter.
I also have a Fora Jr earmarked for an APS Princess and an MVVS DFS/R for a Modelhob Smousen.
Oh and 2 Irvine 20 diesels one for a part built Hallam Big Peacekeeper
And the other for a Henri Stouffs Blue Pants.
Annette
ID:	1989260   Click image for larger version
Old 04-26-2014, 12:31 AM
  #173
123Cat
You must be the luckiest person on earth Telmore , first class selection
Old 04-27-2014, 09:04 PM
  #174
Warren B
Here's one that has turned out rather well.
A VERY simple all balsa Spitfire.
About 30" span, 12 ounces with a DC Super Merlin.
All tissue trim with 2 pack clear floor finish.
Lemon receiver and battery ticked away in centre section box which also forms the dihedral brace.
Fuselage is stiffened with a carbon tube down the centre.
Flies well on rudder/elevator.
Lovely "Spitfire" style rolls and nice loops and reversals.
The Merlin has just the right amount of power and starts in a few flicks on the running settings, no mucking about with priming needed - lovely!
Even the glide isn't too bad now that I have learned to let it find it's own fast slope.
Name:	IMG_1845 small.jpg
ID:	1990661   Click image for larger version
Name:	IMG_1846 small.jpg
ID:	1990662   Click image for larger version
Name:	IMG_1848 small.jpg
Old 04-30-2014, 03:14 PM
  #175
[email protected]
Just what a Spitfire needs, a Merlin. Jack
