Everything Diesel Discuss R/C Diesel engines here.
Engine Out Characteristics
Old 03-09-2003, 07:16 AM
My Feedback: (77)
nemesis4u's Avatar
Default Engine Out Characteristics
Once the diesel is running..How reliable is it...In terms of mounting 2 diesel converted engines in a twin...You must have absolute reliability,,,Will the Diesel Stay Running once started...Also what is the mixture or formula for running scented oil (lemon scented etc...for lamps) to reduce bad smell..Can one use Lamp oil scented...for fuel?
Old 03-09-2003, 05:09 PM
ddd
When you eliminate the glow plug you eliminate the fact that it may go out. Thats reason is enough to choose a system that does not use a glow plug.
We don't comment on fuel formulas.
I can understand not liking to be behind the bus so to speak, fortunately the plane fly's up in the air not on the ground and only the birds should mind.
Old 06-10-2003, 03:43 AM
AMB
yes it just scented kero with you still need ether,castor or syth\
oil or mixture and ignition improver about a half percent like amyl
nitrate.. plus mixture varies for bushed or ball bearing engines
half A up to .10 old english types,best to buy a premix for type
check davis diesel.
Old 06-10-2003, 11:55 AM
ddd
At the advice of lawyers it is are company policy to not give out fuel formulas or otherwise teach someone how to make fuel. Our premade fuel is available direct from Tower Hobbies by the gallon.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
