Everything Diesel Discuss R/C Diesel engines here.
SuperTigre 3000 Conversion
Old 10-31-2009, 01:43 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default SuperTigre 3000 Conversion
I swapped out the heads on my ancient SuperTigre 3000 and bolted up a JustEngines Jen-C prop. I alson place a SuperTigre 2300 carb one it. The original carb was about the same size as a 4500 carb. It is nice and smooth.
Engine===SuperTigre 3000
Prop ====Jen-C/Biela 20x6
Fuel=====Davis ABC mix
Compression adjustment==50% of its range
Muffler===SuperTigre 3000/4500
RPM=====6,600
Idle=====1,800, lower when I have some more time to tweak a little.
Old 10-31-2009, 04:22 PM
gkamysz
My Feedback: (19)
gkamysz's Avatar
Default RE: SuperTigre 3000 Conversion
That's about 2/3 the power DDD claim on the website?
Greg
Old 10-31-2009, 05:04 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
That engine has a ton of hours on it and has very soft compression, guess what, the genuses at Tower have a cylinder but no piston or ring. There is a NIB one for sale in the MarketPlace, I may grab it. As Mr. Davis said, a conversion won't make an old engine new.
Old 10-31-2009, 06:18 PM
AMB
Hobbsy maybe a quick cheap fix would be a ring from Frank Bowman you know the drill get the glaze off the liner toss on the ring martin
Old 10-31-2009, 06:39 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I have an 18x10 and a 20x6 MA Classic I can try, the Jen-C turns hard even my Saito 2.20 struggles with it.
Old 10-31-2009, 06:57 PM
AMB
my guess 7200 -7300 with the MA martin
Old 11-01-2009, 07:51 AM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Martin, I have a new ring coming from Frank Bowman and a new piston from Tower, now if I could only find a new cylinder. Tower has some 3000 stuff if you scrounge around enough. You'd think their search engine would find all things 3000 related but it doesn't.
Old 11-01-2009, 04:57 PM
Recycled Flyer
Mate, I have to ask, how many engines do you actually have? (Excluding the tractor in your side bar of course!)
Cheers.
Old 11-01-2009, 06:18 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I think I have about 100 with about 30 being Diesels.
Old 11-06-2009, 06:51 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Martin, the Frank Bowman rings came today, I ordered two. I skinned up the cylinder with some 150 sandpaper and had to do some serious cleaning on the ring groove. Even unrun it has way better compression with the new ring. I put a new gasket set in it, really they are two O rings and a new copper head gasket. I'll run about an hours worth of glow fuel through it and re-Dieselize it.
