Everything Diesel Discuss R/C Diesel engines here.
Diesel fueler
Old 11-07-2009, 04:35 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Default Diesel fueler
I made this using a primer pump I got on ebay for 5 for $8. I'm relatively new to diesels, I like the little ones, now I read that the fuel shouldn't be left in a plastic container for more than a couple hours. I've had the fuel in it for 2 days at between 35* and 59*F. Did I ruin the fuel? If I did ruin it can I buy a can of starter fluid to put the ether back in.
I have taken the fuel out of the fueler for now.
Old 11-07-2009, 04:43 PM
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Diesel fueler
Rich, I've left Davis fuel sit in a fuel tank for a week or so with the inlet and outlet tube joined with a piece of bent brass tubing. I did not have a problem that way.
Old 11-07-2009, 05:09 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Thanks, that makes me feel better.
Old 11-07-2009, 06:27 PM
fiery
Rich
That aircraft is just too cute. Nice set-up.
What is it? And what is the powerplant? Is it the PAW 55?
Old 11-07-2009, 07:00 PM
soarrich
My Feedback: (98)
soarrich's Avatar
ORIGINAL: fiery
Rich
Thanks.
It's the PAW 55 .033 cu in. The plane is a Scoundrel, mine was built from a pre-production kit I got from Steve at http://www.selecthobbies.com
It's my first attemt a silk and dope. I did a thread on it in 1/2a forum http://www.rcuniverse.com/forum/m_9177606/tm.htm
Old 11-08-2009, 02:01 AM
qazimoto
ORIGINAL: soarrich
Rich,
I'd be much more worried about the consequences of using that electric starter on a PAW 55
Old 11-08-2009, 09:03 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Yes, I know. I'm very carfull to hand flip it first and not have it over compressed. As I get better at starting and tuning it the starter should go away.
Motorboy
Motorboy's Avatar
The instruction from PAW:
Never allow fuel to stand open, to be mixed, or to be left in a plastic container for longer than 2 hours, as it can ruin the fuel. Keep fuel in a tightly closed metal can.
Some material/stuff in plastic fuel tank or plastic can can have stuff who are dissolving by the ether and releasing unwanted substances from plastic material or make the ether are useless for the engine as ignitor.
Pure ether can dissolve some plastic material very effective. When i am mixing own fuel, i am using measure cup made of glass.
Edit: some are wrong with the last text size and can not be edited..
Old 11-08-2009, 09:10 AM
soarrich
My Feedback: (98)
soarrich's Avatar
Carpe diem quam minimum credula postero
For those of you who don't read Latin, that translates to :
Fish today worry little your credit is plastered.
